Engine bay cable "snorkel", installation advise |
draganc |
Feb 7 2019, 11:09 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
hi folks!
any advise how to install the rubber engine "snorkel", covering the wire harness exiting the tunnel? The original rubber grommet is all cracked up and I was think it would be a good idea to replace, while the engine is out. I have been staring at it for an hour, but can only come up with disassembling all the connectors and even then it looks like a tight fit. Any "alternative repair" advises are also very much appreciated. Cheers, dc |
Specracer |
Aug 20 2019, 09:27 AM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
I went a different route, the snorkel was cracked, but the ends going to the shelf and bulkhead, were OK. I just could not stomach changing the snorkel, even when the harness was out of the car. I used a waterproof tape that I found on Amazon. Its a stretchy self clinging rubber membrane. Secured with a wire tie at the end to guarantee it wouldn't unravel.
porschetub |
Sep 1 2019, 03:21 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I went a different route, the snorkel was cracked, but the ends going to the shelf and bulkhead, were OK. I just could not stomach changing the snorkel, even when the harness was out of the car. I used a waterproof tape that I found on Amazon. Its a stretchy self clinging rubber membrane. Secured with a wire tie at the end to guarantee it wouldn't unravel. I took a look @ mine before fitting the engine and it was starting to split in some places so I cleaned it many times until spotless,used 3/4" loom tap and its still good,I didn't have the time to wait for a new one and thought replacement may be tricky. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:46 AM |
