123 Bluetooth Distributor, How does everyone like theirs? |
mmichalik |
Feb 9 2019, 12:23 PM
MikeM Group: Members Posts: 689 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I'm about ready to put the new clutch in and mate the transmission up to the motor. I've replaced the hexbar linkage with the Tangerine racing cable set up and I now want to add the 123 Bluetooth distributor.
I know that we had a GB last year or so and I wanted to get everyone's opinion before I spend the money. I would also like to know which model number was purchased. I sent an email to them asking which one was the correct version for the motor but, I don't believe I ever received a response. (in all fairness, it might have gone into the junk folder and been arbitrarily deleted) Any thoughts, wisdom, sage advice and/or part number would be awesome. Thanks, Mike |
Olympic 914 |
Feb 12 2019, 08:52 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I suppose that the djet version with connections for trigger points somehow removes the possibility of having it be programable either through Bluetooth or a PC.
That said I would have liked to be able to program the curves with my djet version. Running a different cam than stock (Raby 9590) and jake recommends a starting advance of 16 BTDC and full advance of 30-32. all of the djet compatible 123 ignition dizzys have around 22 degress advance on the various programs installed instead of the 14-16 deg advance that would be optimal for this cam. although my old dizzy was no better, I could have had the curves altered. |
914_teener |
Feb 12 2019, 07:42 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I suppose that the djet version with connections for trigger points somehow removes the possibility of having it be programable either through Bluetooth or a PC. That said I would have liked to be able to program the curves with my djet version. Running a different cam than stock (Raby 9590) and jake recommends a starting advance of 16 BTDC and full advance of 30-32. all of the djet compatible 123 ignition dizzys have around 22 degress advance on the various programs installed instead of the 14-16 deg advance that would be optimal for this cam. although my old dizzy was no better, I could have had the curves altered. Running a different cam than stock (Raby 9590) and jake recommends a starting advance of 16 BTDC and full advance of 30- At what rpm? |
Olympic 914 |
Feb 13 2019, 03:24 PM
I suppose that the djet version with connections for trigger points somehow removes the possibility of having it be programable either through Bluetooth or a PC. That said I would have liked to be able to program the curves with my djet version. Running a different cam than stock (Raby 9590) and jake recommends a starting advance of 16 BTDC and full advance of 30-32. all of the djet compatible 123 ignition dizzys have around 22 degress advance on the various programs installed instead of the 14-16 deg advance that would be optimal for this cam. although my old dizzy was no better, I could have had the curves altered. Running a different cam than stock (Raby 9590) and jake recommends a starting advance of 16 BTDC and full advance of 30- At what rpm? Rpm not stated. Here > http://www.914world.com/bbs2/index.php?sho...255127&st=0 |
Lo-Fi Version | Time is now: 25th April 2024 - 05:37 AM |
