123 Bluetooth Distributor, How does everyone like theirs? |
mmichalik |
Feb 9 2019, 12:23 PM
MikeM Group: Members Posts: 688 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I'm about ready to put the new clutch in and mate the transmission up to the motor. I've replaced the hexbar linkage with the Tangerine racing cable set up and I now want to add the 123 Bluetooth distributor.
I know that we had a GB last year or so and I wanted to get everyone's opinion before I spend the money. I would also like to know which model number was purchased. I sent an email to them asking which one was the correct version for the motor but, I don't believe I ever received a response. (in all fairness, it might have gone into the junk folder and been arbitrarily deleted) Any thoughts, wisdom, sage advice and/or part number would be awesome. Thanks, Mike |
jim_hoyland |
Feb 13 2019, 02:41 PM
Get that VIN ? Group: Members Posts: 9,256 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Curious. What might be a weakness in the 1-2-3 ? Every distributer I’ve used had a weak point...
Currently i’m Running the Mallory Unilite that I acquired from Tangerine Racing years ago. I improved performance and has only two issues. 1. The 4 cyclinder model is no longer made and parts are NLA 2. The optical sensor is extreamly sensitive to any voltage spike and always results in a complete shutdown until the optical sensor is replaced. I’m thinking of replacing the Mallory Unilite with a 1-2-3 on my 1975 L-Jet Now sure which model; I have no Vac port on the new Vanagon TB Any suggestions will be appreciated plus the Mallory May need s new home ‘ |
914_teener |
Feb 13 2019, 04:41 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Curious. What might be a weakness in the 1-2-3 ? Every distributer I’ve used had a weak point... Currently i’m Running the Mallory Unilite that I acquired from Tangerine Racing years ago. I improved performance and has only two issues. 1. The 4 cyclinder model is no longer made and parts are NLA 2. The optical sensor is extreamly sensitive to any voltage spike and always results in a complete shutdown until the optical sensor is replaced. I’m thinking of replacing the Mallory Unilite with a 1-2-3 on my 1975 L-Jet Now sure which model; I have no Vac port on the new Vanagon TB Any suggestions will be appreciated plus the Mallory May need s new home ‘ Jim...I'd pull the trigger with this. |
Lo-Fi Version | Time is now: 19th April 2024 - 11:29 PM |
