914 2.0 core engine SOLD 2.0 with sheetmetal $650., 1.8 big valve heads SOLD |
914ltd |
Feb 10 2019, 02:44 PM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
The GA engine is a long block and doesn't turn. $400. plus ship SOLD
The other engine is a 1.8 numbered block with 2.0 heads that was built for a track car. Includes distributor and alternator clutch and flywheel. I removed it in running condition but the compression was low. Includes sheet metal. $650. plus ship Pair of 1.8 big valve heads with double valve springs, the heads have been bored to 112mm for an oversize piston/cylinder. I measured the valves 39 and 47mm but they are probably 38 and 48. The seats almost touch and there is a open spot in the aluminum between them. I don't know if this is normal? $110. for the pair plus ship. Brad Mayeur Heads SOLD Attached thumbnail(s) Attached image(s) |
914ltd |
Mar 13 2019, 10:35 AM
Bump
Lo-Fi Version | Time is now: 26th April 2024 - 02:27 AM |
