Fuel pump issues, anyone had the Carter (CB) pump fail early in life? |
porschetub |
Feb 10 2019, 10:21 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Car is out from the cover of my shed while I do renovation work on my house to sell it,been tucked away under car covers @ the rear of my house ,went to move it to other undercover storage and the fuel pump was a no go,checked relay,replaced earth lead which was a bit dodgy,fuse on my rebuilt relay board is ok,a bit lost on this as the pump has only done low hours.
Anyone had one fail ? or other suggestions what to look for before I proceed further but I have little time for this (IMG:style_emoticons/default/sad.gif) . |
Mark Henry |
Feb 11 2019, 08:56 AM
Did you try running a wire direct? good ground?
porschetub |
Feb 11 2019, 12:21 PM
Thanks Mark ...no I haven't will try to find time today.
rfinegan |
Feb 11 2019, 12:33 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I picked up a little debris that ties up the pump and stalled the motor. I reversed the polarity and spun the pump backwards and it cleared the bind and started to spin again. Hook everything back up and is still working to date
porschetub |
Feb 12 2019, 12:04 AM
Strange shit going down,cycled the key a few times and the pump finally woke up,3 pumps on the throttle and hand throttle on full and the six fired up and ran great,up to temp and then the pump tips over again..... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) .
Hate to say it but think power from relay board to pump is shite but why is my relay board fuse showing no power with key on..just don't know or have the time. Will power the pump up from another supply tomorrow ...see how it pans out. |
Krieger |
Feb 12 2019, 12:15 AM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Your ignition switch may be ending its career.
porschetub |
Feb 12 2019, 08:23 PM
Your ignition switch may be ending its career. Hi yeah know the issue with the switches,one I have is near new (done 500kms ),more tests showed power direct to pump with a battery and it works,supply wire has continuity to pin 13 on 14pin relay board connector so that's a good start, appears to have power with key on to fuel pump fuse (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . Stuffed around with various other things one being a relay change and bingo won a price ,pump worked,appears the large amount of spare relays supplied by PO are suspect (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/slap.gif) . My whole electrical system has gremlins everywhere which pisses me off however now I can move the car to undercover storage. Thanks to all that provided tips and feel like a dick cause I should know better but dealing with 40+yr old parts is a crapshoot afterall. |
porschetub |
Feb 13 2019, 08:16 PM
Your ignition switch may be ending its career. Hi yeah know the issue with the switches,one I have is near new (done 500kms ),more tests showed power direct to pump with a battery and it works,supply wire has continuity to pin 13 on 14pin relay board connector so that's a good start, appears to have power with key on to fuel pump fuse (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . Stuffed around with various other things one being a relay change and bingo won a price ,pump worked,appears the large amount of spare relays supplied by PO are suspect (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/slap.gif) . My whole electrical system has gremlins everywhere which pisses me off however now I can move the car to undercover storage. Thanks to all that provided tips and feel like a dick cause I should know better but dealing with 40+yr old parts is a crapshoot afterall. Update Well my fix hasn't worked,boxed up gravel guard over pump lowered the car back down ,added fresh fuel tried to start but pump not working again (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) ,I had previously checked it many times yesterday and worked first time every time,pulled the relay board and found the positive on the pump fuse a little melted and loose ,I thinks there is a poor contact in side of the board. My plan is to transpose pins 11 and 13 on the 14 pin plug and run off the heater boost fan /rear heated window circuit with smaller fuse for my fuel pump...should work ok (IMG:style_emoticons/default/confused24.gif) . |
porschetub |
Feb 15 2019, 01:00 PM
Been busy with contractors on my house,problem was the issue with the car was bugging to the point of distraction.
Next day I have some time in the morning and couldn't stop thinking it was a relay problem as all tests done according to past threads on here pointed to that,found a large bag of spare ones and tested them using my RH side headlight motor and marked them good or bad,found 4 that were dead. I then tested what relays still left on the board and found the power supply one was buggered which explained my issues. Car up and running ,lets hope that is the end of it. |
Lo-Fi Version | Time is now: 25th April 2024 - 01:07 AM |
