Fuel pump issues, anyone had the Carter (CB) pump fail early in life? |
porschetub |
Feb 10 2019, 10:21 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Car is out from the cover of my shed while I do renovation work on my house to sell it,been tucked away under car covers @ the rear of my house ,went to move it to other undercover storage and the fuel pump was a no go,checked relay,replaced earth lead which was a bit dodgy,fuse on my rebuilt relay board is ok,a bit lost on this as the pump has only done low hours.
Anyone had one fail ? or other suggestions what to look for before I proceed further but I have little time for this (IMG:style_emoticons/default/sad.gif) . |
porschetub |
Feb 15 2019, 01:00 PM
Been busy with contractors on my house,problem was the issue with the car was bugging to the point of distraction.
Next day I have some time in the morning and couldn't stop thinking it was a relay problem as all tests done according to past threads on here pointed to that,found a large bag of spare ones and tested them using my RH side headlight motor and marked them good or bad,found 4 that were dead. I then tested what relays still left on the board and found the power supply one was buggered which explained my issues. Car up and running ,lets hope that is the end of it. |
Lo-Fi Version | Time is now: 24th April 2024 - 07:45 PM |
