WTB: NOS or good working Vacuum unit for 73 2.0 distributor, This is the two nipple unit #601 |
SRS914 |
Feb 11 2019, 07:16 PM
Newbie Group: Members Posts: 22 Joined: 10-August 18 From: Laguna Beach Member No.: 22,379 Region Association: Southern California |
Part #R022905271C. Number on Arm should read 601.
914Sixer |
Feb 11 2019, 09:04 PM
914 Guru Group: Members Posts: 8,889 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Post the number on the arm of the vacuum unit. Lots of confusion about what is correct.
SRS914 |
Feb 12 2019, 12:37 AM
Will do tomorrow Mark. Not even sure the correct part is in the car at this point though.
SRS914 |
Feb 12 2019, 12:59 AM
Researching some old posts here is what I found
according to the old Bosch list the Bosch #s should be: 1973: 039 905 205 (vac canister 022 905 271 C): 0 231 174 010 (009 without VW sign/logo), up to 1973/6 |
SRS914 |
Feb 13 2019, 02:35 PM
I now understand that there is a number on the arm of the unit that identifies what part this is. The number on the arm for the part I'm looking for is 839.
KevinW |
Feb 13 2019, 06:05 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
I now understand that there is a number on the arm of the unit that identifies what part this is. The number on the arm for the part I'm looking for is 839. I found this chart, I have no idea of the accuracy. I have a few 2.0 distributors 205, and 205A and the arms have a 979 number. I was not able to find that number on the chart. I also have two 917 (0 231 174 007) distributor, 831 (0 229 905 205F) distributor. 815 I was not able to locate this number on the chart. Attached thumbnail(s) |
SRS914 |
Feb 13 2019, 10:56 PM
That is very helpful and interesting. My best guess is that the 831 would be the right part.
SRS914 |
Feb 16 2019, 02:05 PM
Bump
914_7T3 |
Feb 16 2019, 02:35 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
You may find this parts list to be one of the better available references
https://members.rennlist.com/pbanders/djetparts.htm |
SRS914 |
Feb 16 2019, 07:13 PM
You may find this parts list to be one of the better available references https://members.rennlist.com/pbanders/djetparts.htm That is exactly what I needed. Thank you! |
porscheaddic |
Feb 17 2019, 03:17 PM
Member Group: Members Posts: 68 Joined: 9-July 07 From: california Member No.: 7,898 |
Part #R022905271C. Number on Arm should read 601. I found this new vacuum unit with the numbers 807. Maybe someone can chime in and tell us what engine it works with. Asking $80. Thanks Attached image(s) |
SRS914 |
Feb 17 2019, 05:43 PM
Good question, I have no idea what that fit.
Lo-Fi Version | Time is now: 23rd May 2024 - 06:07 PM |
