Lifts, 2 Post Hydraulic Lift Questions |
ctc911ctc |
Feb 14 2019, 11:25 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear. I am thinking about installing a 2 post lift where each post would be against the walls, out of the way. I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift. 1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)? 2. How deep do the anchors need to be placed into the floor? Very little detail on web sites. 3. Are there any preferences as to vendors? I have been looking at this one: https://www.toolots.com/two-post-car-lift-l...#productDetails My requirements are that the lift be as small (footprint) and safe as possible. THANK YOU ALL TEENERS! CTC911CTC |
Chi-town |
Feb 15 2019, 02:25 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
If you can't go up, what about down?
Cut the floor, drop it 6"and pour it as thick as you need and gain a bit of height without touching the ceiling. |
mepstein |
Feb 15 2019, 02:55 PM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
If you can't go up, what about down? Cut the floor, drop it 6"and pour it as thick as you need and gain a bit of height without touching the ceiling. Expensive but possible an option. Might have to check with an engineer before you remove the floor next to a wall. |
ctc911ctc |
Feb 15 2019, 08:07 PM
Good thing I am an engineer! The concrete is 100 years old and not a crack. Not sure why it survived 100 winters but I would not cut it up.......thought about it.......just can’t do it. If you can't go up, what about down? Cut the floor, drop it 6"and pour it as thick as you need and gain a bit of height without touching the ceiling. Expensive but possible an option. Might have to check with an engineer before you remove the floor next to a wall. |
Lo-Fi Version | Time is now: 20th May 2024 - 08:53 AM |
