Lifts, 2 Post Hydraulic Lift Questions |
ctc911ctc |
Feb 14 2019, 11:25 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear. I am thinking about installing a 2 post lift where each post would be against the walls, out of the way. I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift. 1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)? 2. How deep do the anchors need to be placed into the floor? Very little detail on web sites. 3. Are there any preferences as to vendors? I have been looking at this one: https://www.toolots.com/two-post-car-lift-l...#productDetails My requirements are that the lift be as small (footprint) and safe as possible. THANK YOU ALL TEENERS! CTC911CTC |
ClayPerrine |
Feb 14 2019, 12:59 PM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You are not going to get most two post lifts under an 8 foot ceiling. My garage is 10ft ceiling, and it is ok for short cars (and a short mechanic). When I put my truck on there, I have to sit on a stool to be able to work.
If you are doing construction on the building, make the ceiling 12ft. Then you get a lot more choice in lifts. My $/02. Clay |
ctc911ctc |
Feb 14 2019, 01:02 PM
Not going to happen, brick carriage house, rebuilding would ruin many things,
Thank you, CTC911CTC You are not going to get most two post lifts under an 8 foot ceiling. My garage is 10ft ceiling, and it is ok for short cars (and a short mechanic). When I put my truck on there, I have to sit on a stool to be able to work. If you are doing construction on the building, make the ceiling 12ft. Then you get a lot more choice in lifts. My $/02. Clay |
Lo-Fi Version | Time is now: 10th May 2024 - 04:58 AM |
