Lifts, 2 Post Hydraulic Lift Questions |
ctc911ctc |
Feb 14 2019, 11:25 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear. I am thinking about installing a 2 post lift where each post would be against the walls, out of the way. I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift. 1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)? 2. How deep do the anchors need to be placed into the floor? Very little detail on web sites. 3. Are there any preferences as to vendors? I have been looking at this one: https://www.toolots.com/two-post-car-lift-l...#productDetails My requirements are that the lift be as small (footprint) and safe as possible. THANK YOU ALL TEENERS! CTC911CTC |
Freezin 914 |
Feb 26 2019, 06:14 PM
Senior Member Group: Members Posts: 852 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
As some of you know, I just bought a mid rise lift used. $900. New 1500. 6000lbs.
Max lift height of around 60in. Depending on adaptors used, can be more, less. Haven’t used it yet. But some have chimed in already. Nobody regrets buying a lift. Attached image(s) |
Mark Henry |
Feb 27 2019, 06:07 AM
One thing I don't like about some of the scissor lifts is no rubber pads, sitting on steel does make for a car slipping around. I don't know how many times I almost lost an engine on my steel top lift table, till I grew a brain and started using a rubber sheet on it. The above lift I'd use hockey pucks on the lift points to give it some grip. |
Lo-Fi Version | Time is now: 9th May 2024 - 10:12 PM |
