Lifts, 2 Post Hydraulic Lift Questions |
ctc911ctc |
Feb 14 2019, 11:25 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear. I am thinking about installing a 2 post lift where each post would be against the walls, out of the way. I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift. 1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)? 2. How deep do the anchors need to be placed into the floor? Very little detail on web sites. 3. Are there any preferences as to vendors? I have been looking at this one: https://www.toolots.com/two-post-car-lift-l...#productDetails My requirements are that the lift be as small (footprint) and safe as possible. THANK YOU ALL TEENERS! CTC911CTC |
76-914 |
Apr 4 2019, 08:34 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm lucky there. My hose slips into the recess of the slabs expansion joint so the hose is semi recessed. The best accessory I have found for my Max Jack are the Harbor Freight small furniture dollies. They allow me to use the 4" extensions that come with it. Raise the car 3-4" then lower onto the dollies. Once on the dolly the extensions can be fitted. Why furniture dollies instead of blocks. Try it and you'll find out. Bottom line: Any lift is better than no lift. Get what you can afford and whatever fits. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 10th May 2024 - 08:18 AM |
