Lifts, 2 Post Hydraulic Lift Questions |
ctc911ctc |
Feb 14 2019, 11:25 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear. I am thinking about installing a 2 post lift where each post would be against the walls, out of the way. I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift. 1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)? 2. How deep do the anchors need to be placed into the floor? Very little detail on web sites. 3. Are there any preferences as to vendors? I have been looking at this one: https://www.toolots.com/two-post-car-lift-l...#productDetails My requirements are that the lift be as small (footprint) and safe as possible. THANK YOU ALL TEENERS! CTC911CTC |
mlindner |
Apr 4 2019, 12:15 PM
Senior Member Group: Members Posts: 1,518 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
914_teener |
Apr 4 2019, 12:24 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Ben, just get a cement blade for your circular saw. Saw two groves 3/4 inch apart and 3/4 inch deep, hit with hammer/chisel. I ran mine then filled channel with flexible cement caulk. See bottom right corner gives you a little peak of the flat floor. Best, Mark Curious...... What is the capacity of that lift? |
Lo-Fi Version | Time is now: 9th May 2024 - 10:48 PM |
