Lifts, 2 Post Hydraulic Lift Questions |
ctc911ctc |
Feb 14 2019, 11:25 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear. I am thinking about installing a 2 post lift where each post would be against the walls, out of the way. I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift. 1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)? 2. How deep do the anchors need to be placed into the floor? Very little detail on web sites. 3. Are there any preferences as to vendors? I have been looking at this one: https://www.toolots.com/two-post-car-lift-l...#productDetails My requirements are that the lift be as small (footprint) and safe as possible. THANK YOU ALL TEENERS! CTC911CTC |
Krieger |
Sep 28 2019, 10:43 AM
Advanced Member Group: Members Posts: 4,706 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Now I am considering the move to the two post lift. I have had an EZ car lift for at least 10 years, but I want to stop rolling around on the ground and stand or as close to that as possible. I have a good size garage that is 25'×25' with 10' high ceilings. What are the electrical requirements for these lifts? Is 110 enough?
ClayPerrine |
Sep 28 2019, 08:19 PM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Now I am considering the move to the two post lift. I have had an EZ car lift for at least 10 years, but I want to stop rolling around on the ground and stand or as close to that as possible. I have a good size garage that is 25'×25' with 10' high ceilings. What are the electrical requirements for these lifts? Is 110 enough? Every two post lift I have ever seen requires 220V ac to work. Have an electrician wire up a new circuit from your breaker panel to the lift. |
Lo-Fi Version | Time is now: 10th May 2024 - 10:47 AM |
