source for targa latch spring, is this a special part? |
914 RZ-1 |
Feb 15 2019, 08:57 PM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm missing a spring for the rear targa latches. It's the one that go on the latches on the rear targa pad that secure the back of the top to the car.
Is this a spacial part, or are these available at hardware stores? There is no part number in the PET. |
76-914 |
Feb 16 2019, 11:33 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,483 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
It is probably part of the assm. Hit up Bruce Stone for another. (IMG:style_emoticons/default/beerchug.gif)
bbrock |
Feb 16 2019, 11:35 AM
I don't think it is anything special. If you have one, you could probably find a close match at Ace Hardware.
dr914@autoatlanta.com |
Feb 16 2019, 12:46 PM
914 Guru Group: Members Posts: 7,810 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
they are in the Wurth or Winzer spring assortment, those are the ones we use along with our reproduction top hook
bdstone914 |
Feb 17 2019, 12:11 PM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm missing a spring for the rear targa latches. It's the one that go on the latches on the rear targa pad that secure the back of the top to the car. Is this a spacial part, or are these available at hardware stores? There is no part number in the PET. I buy 12 inch lenghts of coil spring material and hand make them. I can get you a small lenght to make your own. I did not find an exact match but use spring material from McMaster Carr that is close and works well. I have not seen the springs in the Wurth assortment that George mentioned. |
Lo-Fi Version | Time is now: 19th April 2024 - 03:59 AM |
