side passenger window install question, rubber piece or urethane caulk? |
914 RZ-1 |
Feb 16 2019, 03:29 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I found the thread on installing the side windows (not the little triangular ones, but the big ones). They state to use urethane caulk (3M Windo-Weld # 08609) to attach them to the rail on the window mechanism. However, the factory install uses a rubber u-channel.
I'd rather use the u-channel, since it doesn't appear that using the caulk allows for any adjustment fore and aft after it cures. My windows were taken out to paint the car so I have no reference for putting them back. The window install post stated to measure about 4-3/16" (106mm) from the front, but what is the tolerance? I'm thinking there could be some variance in location plus or minus 1/4" (6mm). I thought of setting the window in place, but I won't have the triangle window in, so there will be nothing to reference the location off of. Any ideas on solutions? Where can I get the u-channel? Also, is the u-channel glued in or just friction-fit? |
rgalla9146 |
Feb 17 2019, 06:52 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Do you have the rubber U ? It's friction fit if the metal part is intact....they do rust and loose grip. without the rubber you will have rig something to make the rail stand straight on a mechanism that is already marginal. early window parts can be found |
914 RZ-1 |
Feb 17 2019, 11:30 AM
The metal parts I have are in great shape. I only have one rubber channel. I thought I might try and find some rubber sheet and make another channel.
The 3M caulk is $31a tube, so I thought I'd try an alternative first. I want adjustability as well; the caulk doesn't give me that. |
jsaum |
Feb 17 2019, 12:36 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I used urethane when I did my drivers window. I got the angle wrong and the window sits high in the front so when rolled up it doesn’t seal correctly. I didn’t realize there was a rubber u channel used at the factory. Make sure you get it lined up and sealing good if you glue it.
Mikey914 |
Feb 17 2019, 12:39 PM
The rubber man Group: Members Posts: 12,656 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Attached thumbnail(s) |
jsaum |
Feb 17 2019, 04:13 PM
The metal parts I have are in great shape. I only have one rubber channel. I thought I might try and find some rubber sheet and make another channel. The 3M caulk is $31a tube, so I thought I'd try an alternative first. I want adjustability as well; the caulk doesn't give me that. Can you post a picture of the rubber u channel? |
914 RZ-1 |
Feb 18 2019, 07:53 PM
Here's the rubber U-channel:
It is 2.5mm thick. I found another one! It was stuck in the metal channel. The one I had was stuck on the window. I was able to carefully pry it out. I'm going to reuse both of them. They appear to have been secured with some caulk of some sort as there is still residue. I could rub most of it off with my fingers. I will obtain some butyl caulk and secure them with that. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:56 AM |
