side passenger window install question, rubber piece or urethane caulk? |
914 RZ-1 |
Feb 16 2019, 03:29 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I found the thread on installing the side windows (not the little triangular ones, but the big ones). They state to use urethane caulk (3M Windo-Weld # 08609) to attach them to the rail on the window mechanism. However, the factory install uses a rubber u-channel.
I'd rather use the u-channel, since it doesn't appear that using the caulk allows for any adjustment fore and aft after it cures. My windows were taken out to paint the car so I have no reference for putting them back. The window install post stated to measure about 4-3/16" (106mm) from the front, but what is the tolerance? I'm thinking there could be some variance in location plus or minus 1/4" (6mm). I thought of setting the window in place, but I won't have the triangle window in, so there will be nothing to reference the location off of. Any ideas on solutions? Where can I get the u-channel? Also, is the u-channel glued in or just friction-fit? |
jsaum |
Feb 17 2019, 12:36 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I used urethane when I did my drivers window. I got the angle wrong and the window sits high in the front so when rolled up it doesn’t seal correctly. I didn’t realize there was a rubber u channel used at the factory. Make sure you get it lined up and sealing good if you glue it.
Lo-Fi Version | Time is now: 19th May 2024 - 04:31 AM |
