Wiper washer connections at switch...4 connections? |
doug_b_928 |
Feb 18 2019, 10:45 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Did some washer switches have 4 connections for water lines? Mine has the usual two lines that go through the firewall, but there is a third line that appears to 'jumper' two additional ports (see below). Is this normal? (IMG:style_emoticons/default/confused24.gif)
Chi-town |
Feb 18 2019, 11:01 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
For the euro headlamp washers?
doug_b_928 |
Feb 18 2019, 11:36 AM
Hmmm...that would be consistent with this mystery pump that Jeff Bowlsby posited might be for the headlight washers.
The front bumper top doesn't have holes for nozzles and my car is a NA model. Maybe someone on the line thought that this car was getting that option... |
914Sixer |
Feb 18 2019, 12:26 PM
Not for headlight washers. It used a Audi/VW pump. Make sure your hose is not double back into column. There is only room for two hose connections.
dr914@autoatlanta.com |
Feb 18 2019, 12:33 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 17th May 2024 - 04:25 PM |
