914 Airbox HELP, air box control lever fastening bolt |
Str1974 |
Feb 26 2019, 10:30 AM
Member Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
Help, I just refurbished my air box (1974 1.8) with new seals etc. After getting the air box assembled and back into it's place under fresh air vent (what a pain to get those two bolts to line up...)
I can't find the bolt that I had disconnected from the cable (see image #3) As usual I put it in a special place so I would not lose it....yea right. I have gone thru the parts diagram available and I cannot find the bolt that has the small hole in it that allows the cable to go thru it and fasten with washer /nut. I have found the part# for the fastening clamp, but not for the bolt at the end of cable. All the bolts I see available do not have the "eye" hole in it for the cable to go thru and tighten. It won't take a barrel nut in its place. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:58 PM |
