GB for positive cable engine tin grommet GB ends 3.16.19, Other generics don't compare this is why- $4.20 each |
Mikey914 |
Feb 27 2019, 07:14 PM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This grommet the factory designed to help hold the cable away from the tin. It has 2 internal ribs that I felt were critical to the design of this piece. Yes, you can put a generic grommet in the hole, but there are a few of us that have seen these wear, there is a reason the factory spent the extra money to male them this way.
I was looking in the parts catalog and couln't readily find the part number. Not sure if these were sold as part of the battery cable assembly or not. Either way here are some basic pics that will give you the idea of what I'm describing here. Just bump this thread for the discount code and as soon as we have it put together I'll PM you. You will be able to combine to save a a couple of bucks with the other GB that is currently going. Just need a few days to get good pics and make the listing. Who's in? Attached thumbnail(s) Attached image(s) |
Mikey914 |
Mar 7 2019, 01:05 AM
Thanks for your patience,
I just sent all that responded here both codes so you have both codes. Gonna keep this GB alive til the 16th. I have a few more item that should be ready towards the end of the month too! -Mark (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 28th March 2024 - 08:04 AM |
