Seat Frame: New Challenge, Reassembly & Seat Handle Rails |
914_7T3 |
Mar 2 2019, 12:58 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Looking to have my seat frames powder coated and need to remove the non-painted handle assembly as it contains plastic bushings that will melt at high temperature.
Any idea on the correct procedure and tools required for removal? |
Mikey914 |
Mar 18 2019, 06:07 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the tool holds the pin so you can get it installed without trying to use something else to hold it. As far as the roll pins I actually used the ones in the kit for my seat. Perhaps some variation? Let me know the size you used and I can include a set of them also so regardless of the one you have you'll have the pins you need. Again one more variation where I thought there wouldn't be one.
bbrock |
Mar 18 2019, 07:38 AM
As far as the roll pins I actually used the ones in the kit for my seat. Perhaps some variation? Let me know the size you used and I can include a set of them also so regardless of the one you have you'll have the pins you need. Again one more variation where I thought there wouldn't be one. Interesting. I just reused the original ones so I'm not sure what size. They were only slightly smaller diameter and had a noticeable taper on them. The taper might have just been from being compressed for 47 years. When I started to drive the pin that came with the kit in, it compressed to close the gap before it squeezed small enough to drive into the hole. I thought about using my Dremel to just grind a little more clearance in the gap, but I had the originals handy and they were still in good shape. I don't remember who, but somebody else recently mentioned running into the same issue. Next time I have the seats out, I'll try to remember to measure the diameter of that pin. |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:59 AM |
