Seat Frame: New Challenge, Reassembly & Seat Handle Rails |
914_7T3 |
Mar 2 2019, 12:58 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Looking to have my seat frames powder coated and need to remove the non-painted handle assembly as it contains plastic bushings that will melt at high temperature.
Any idea on the correct procedure and tools required for removal? |
Olympic 914 |
Mar 18 2019, 05:08 PM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Bolted the seat rails to work table and used a wire and a turnbuckle to pull the spring back.
Its then easy to drive the pin in. just snip the wire off to remove it. |
914_7T3 |
Apr 21 2019, 10:39 PM
Bolted the seat rails to work table and used a wire and a turnbuckle to pull the spring back. Its then easy to drive the pin in. just snip the wire off to remove it. Ended up going with a variation on the theme, albeit a bit ghetto style. An old shoe lace and a pry bar were the tools of choice here...worked like a charm. (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 11:01 PM |
