| Bulldozer27 |
Mar 14 2019, 08:41 PM
Newbie ![]() Group: Members Posts: 48 Joined: 14-November 18 From: Sandy Eggo, CA Member No.: 22,653 Region Association: Southern California |
What about Maxilites? I have 4 practically new 16x7 23.3ET wheels for sale.
| Chris914n6 |
Mar 14 2019, 09:36 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,556 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
They are still around, just at the new French owners crappy website... google had to find it (IMG:style_emoticons/default/headbang.gif)
RIM 7 X 17 ET 23.3 Different company = different rules, like no more sharing. So where there some problems with these wheels or a lot of problems. There was some reason why they stopped importing them. There’s got to be a lot of reviews one way or another. |
| Mikey914 |
Mar 15 2019, 06:08 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,784 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Doing some digging. These are not forged. The actual alloy and specs I’m questioning. No way I’d touch these without mill certs, but may be an “option”.
Let the drama unfold. |
| Spoke |
Mar 15 2019, 07:30 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,427 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I have a set of Euromeisters on my 930. 7x17; 9x17. Didn't have any issues balancing.
I had them road-force balanced. Beautifully smooth ride. Attached thumbnail(s) |
| timothy_nd28 |
Mar 15 2019, 08:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
These rims are not only cheap but they look good. If I were to ruin one by running over a pothole, I wouldn't react as badly vs ruining a real fuch
| Spoke |
Mar 15 2019, 08:32 AM
| restore2seater |
Mar 15 2019, 08:44 AM
Future 914 copilot. ![]() ![]() Group: Members Posts: 313 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
I have a set of Euromeisters on my 930. 7x17; 9x17. Didn't have any issues balancing. I had them road-force balanced. Beautifully smooth ride. @Spoke I had to google that procedure. Never heard of that type of balancing. How much difference in price was it compared to a typical balancer? I would imagine it would be difficult to find a shop that does balancing this way. |
| Spoke |
Mar 15 2019, 09:33 AM
I have a set of Euromeisters on my 930. 7x17; 9x17. Didn't have any issues balancing. I had them road-force balanced. Beautifully smooth ride. @Spoke I had to google that procedure. Never heard of that type of balancing. How much difference in price was it compared to a typical balancer? I would imagine it would be difficult to find a shop that does balancing this way. The place I go to is in Plum outside of Pittsburgh called Golden Mile Tire. A guy at work recommended them. It cost $100 for 4 tires and well worth it. I didn't have the 930 w/Euros done there and had a bit of vibration; not much; just a little bit. Then I noticed a string of wheel weights sitting on the garage floor where the car was parked and the vibration got worse. Took it to Carl at Golden Mile Tire and all vibration was gone. Zero. It makes perfect sense. Spinning the wheel in the air when balancing is fine but the tire isn't run like that. It spins with the weight of the car on it and where that weight is the tire is flatten. So why not balance it with that weight on the wheel? |
| Cevan |
Mar 15 2019, 09:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
| restore2seater |
Mar 15 2019, 11:57 AM
It makes perfect sense. Spinning the wheel in the air when balancing is fine but the tire isn't run like that. It spins with the weight of the car on it and where that weight is the tire is flatten. So why not balance it with that weight on the wheel? Completely agree with this statement. For most drivers the difference probably not important but for perfectionists with a higher end car i can see doing this? Or unless you're someone with OCD. @bbrock , @tygaboy (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 17th September 2026 - 03:09 PM |
