FS Shiny and Powder Coated Parts, Multiples of some parts |
bdstone914 |
Mar 10 2019, 07:32 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
One set of 16 original alloy lug bolts.
Size: 14m x 38m. Replated silver zinc. $150 shipped. Sets of fuel rails and injector hold down clamps. Silver or gold. Several sets $35 for a set of 4 clamps and two rails. Attached thumbnail(s) |
bdstone914 |
Mar 10 2019, 07:34 PM
One pair of early 1970-1972 front strut shaft lock plates. Correct for a 914-6
Edit, Found a second set of late strut plates. SOLD Porsche changed the design to the larger plate. They fit all cars. $25 a pair. Edit, checking for more Sold $25 a set. Attached thumbnail(s) |
bdstone914 |
Mar 10 2019, 07:35 PM
Rear trailing arm bracket L plates. $20 a pair
With new 10m x 55m 10.9 grade bolts and Schnorr washers. $35 for the set. Pictures to follow. MAP sensor bracket. Powder coated. $15 each. Two available. Steering rack bearing yoke. Holds steering rack shaft bearing to the body. $10. Clutch forks. 901 transmissions. Tail or side shift. SOLD $ Attached thumbnail(s) |
bdstone914 |
Mar 10 2019, 07:37 PM
More stuff.
bdstone914 |
Mar 10 2019, 07:38 PM
Powder coated Gas Tank Straps with replated hold down clamp. One
Rear license plate brackets. Powder coated. $20 each. Attached thumbnail(s) |
euro911 |
Mar 10 2019, 08:47 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Bruce, what's the status on my 'late' front strut powder-coating process?
When is your next swap meet scheduled? |
Charles Danek |
Mar 10 2019, 10:01 PM
Newbie Group: Members Posts: 35 Joined: 8-February 15 From: United States Member No.: 18,409 Region Association: Southern California |
Hi Bruce!
How much is the clutch pully cover? I am interested! I am also trying to track down a set of aluminum bushings that fit into the bottom edge of the fiber-board back pad -- I have 1, but I need 3 more -- might you have any of these? Thanks!!! Charlie |
bdstone914 |
Mar 10 2019, 10:33 PM
Hi Bruce! How much is the clutch pully cover? I am interested! I am also trying to track down a set of aluminum bushings that fit into the bottom edge of the fiber-board back pad -- I have 1, but I need 3 more -- might you have any of these? Thanks!!! Charlie $25 for the bracket. Best to make the back pad spacers out of thick wall steel tube. Use with a washer and sheet metal screw. |
Charles Danek |
Mar 10 2019, 10:36 PM
Hi Bruce! How much is the clutch pully cover? I am interested! I am also trying to track down a set of aluminum bushings that fit into the bottom edge of the fiber-board back pad -- I have 1, but I need 3 more -- might you have any of these? Thanks!!! Charlie $25 for the bracket. Best to make the back pad spacers out of thick wall metal tubing. The original wer aluminum and corroded. @Charles Danek Hi Bruce -- Thanks for the tip on spacers -- and I'll take the bracket! Paypal? Charlie |
AHudson |
Mar 11 2019, 03:05 PM
Member Group: Members Posts: 55 Joined: 13-May 18 From: Alabama Member No.: 22,112 Region Association: South East States |
Rear trailing arm bracket L plates. $20 a pair With new 10m x 55m 10.9 grade bolts and Schnorr washers. $35 for the set. Pictures to follow. MAP sensor bracket. Powder coated. $15 each. Two available. Steering rack bearing yoke. Holds steering rack shaft bearing to the body. $10. Clutch forks. 901 transmissions. Tail or side shift. $30 each. Three available. Just PM'd you: will take a clutch fork for a 901 tail shift. Thanks! |
DRPHIL914 |
Mar 11 2019, 06:43 PM
spare tire hold down washer and thingy please
56kabrio |
Mar 11 2019, 10:42 PM
Member Group: Members Posts: 54 Joined: 1-December 05 From: Nashville, TN Member No.: 5,219 Region Association: None |
Spare tire hold down please.
Thanks Mack |
twistedstang |
Mar 12 2019, 06:24 AM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
I'll take the pair of late 1973-1976 front strut shaft lock plates. Paypal?
Thanks |
76-914 |
Mar 12 2019, 08:08 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Nice stuff, great prices. (IMG:style_emoticons/default/beerchug.gif)
bdstone914 |
Mar 12 2019, 10:04 AM
bdstone914 |
cpavlenko |
Mar 12 2019, 10:44 AM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I guess I missed the spare tire hold down and bolt (IMG:style_emoticons/default/sad.gif)
DRPHIL914 |
Mar 12 2019, 12:02 PM
spare tire hold down washer and thingy please Need to see if I have more. First two sold. you sent a pm with payment imstructions etc so i paid you via paypal. bope you had one for me, if not i will wait for the next batch- |
dakotaewing |
Mar 12 2019, 07:42 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
I'll take the gas tank strap assembly as long as the strap is not deteriorated from rust. Send me a PM with payment details please -
Thanks - Thom |
ledfoot |
Apr 3 2019, 12:04 PM
Member Group: Members Posts: 54 Joined: 14-February 06 From: Dayton,OH Member No.: 5,581 Region Association: None |
Bruce,
Made payment on the fuel tank strap on 3/11 and still haven’t recieved my purchase. Please send me a Update... Thanks, Michael |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:33 PM |
