Sway bar bushing lube, glycerine paste substitute |
bbrock |
Mar 12 2019, 03:04 PM
Trying to figure out what to use to lubricate rubber sway bar bushing. The factory manual says to use "glycerine paste" but that appears to be an extinct dinosaur. I'm assuming Red Rubber Grease would be the modern choice but I would have to order it. Then my FLAPS has several brake part greases that are "safe for rubber." I already have a bottle of Permatex Ceramic Extreme Brake Parts Lubricant (pic below) for reassembling my calipers. Should be rubber safe but not sure it is right for the job. I'm just a bit confused by all the choices. Suggestions? (IMG:style_emoticons/default/confused24.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/441py33rout1ptjxn2lupv31-wpengine.netdna-ssl.com-20845-1552424651.1.jpg) |
bbrock |
Mar 12 2019, 06:48 PM
Thanks guys. Where would one find glycerine sulfate paste? Google isn't being my friend.
The problem I see with surgical gel is that it is water based so I think it would dry up and/or wash out. I think the idea is to provide a little permanent lubricant to allow the bar to move a little inside the bushing. |
Lo-Fi Version | Time is now: 18th April 2024 - 08:21 PM |
