Has Anyone Heard Of /Or Done A 6 With A Boxster S Tranny?, Interesting Concept |
Lucky9146 |
Mar 13 2019, 08:37 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,605 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Met a guy at Amelia Island Werks Reunion who said he once owned a 914 with a 3.2 six and it had a Boxster S transmission. He did not do the build himself, said he bought it that way. I'm going down the 915 path currently. Never heard of this combo but was wondering if anyone had? Pros/ cons.
(IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/white914.jpg) |
914-6 GT in waiting Group: Members Posts: 19,222 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Clay is working on one.
Andyrew |
Mar 13 2019, 09:11 PM
I believe the issue is no starter provision. The modern porsche/vw/Audi transaxles have the starter on the motor side.
Racer |
Mar 14 2019, 05:21 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Alan Clapp's 914
The Ultimate 914? 1987 Carrera engine mildly tweaked to about 230 hp; full welded roll cage; 996 TT brakes F & R; chassis reinforcements; 245x35x18" front tires on 9" rims; 285x30x18" rear tires on 10" rims; carbon fiber hoods and bumpers; and the best for last - 2003 Boxster S 6-speed transmission! https://www.pelicanparts.com/porsche/914/91...y/914_clapp.jpg |
flyer86d |
Mar 14 2019, 06:19 AM
Member Group: Members Posts: 419 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Alan Clapp's 914 The Ultimate 914? 1987 Carrera engine mildly tweaked to about 230 hp; full welded roll cage; 996 TT brakes F & R; chassis reinforcements; 245x35x18" front tires on 9" rims; 285x30x18" rear tires on 10" rims; carbon fiber hoods and bumpers; and the best for last - 2003 Boxster S 6-speed transmission! https://www.pelicanparts.com/porsche/914/91...y/914_clapp.jpg What is really cool is that Alan bought the car new. It’s a 1971 or 72 I believe. He was a member of NNJR when I joined in 1976. It was always a really nice original car that was used for club events as a stock 1.7. I doubt it needed restoration when he did the conversion. I frankly was astounded that he converted his long preserved and original car but hell, what a better starting point! Charlie |
BIGKAT_83 |
Mar 14 2019, 07:09 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
A member here also goes by ABC914 do a search.The car is one nice 914.
Lucky9146 |
Mar 14 2019, 09:52 AM
Thanks for all the input! I thought the guy may have been pulling my leg. (IMG:style_emoticons/default/biggrin.gif)
ClayPerrine |
Mar 18 2019, 11:38 AM
Life's been good to me so far..... Group: Admin Posts: 15,394 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There is info on using a 2006 Cayman transmission with a 964 motor in my build thread
http://www.914world.com/bbs2/index.php?sho...9084&st=120 I am making slow progress with it, but it is moving. Clay |
HaraldD |
Mar 18 2019, 12:14 PM
Member Group: Members Posts: 89 Joined: 23-November 08 From: Germany Member No.: 9,781 Region Association: Germany |
Hello,
take a look: https://www.elferteam.de/index.php?/topic/34186-993-im-14er/ Maybe you need a registration.. Harald |
Mark Henry |
Mar 18 2019, 01:01 PM
If I blow up my 914 tranny I might look into this. (IMG:style_emoticons/default/happy11.gif)
Mar 18 2019, 02:24 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There's a thread on the Pelican 914 BBS titled something like "solution to my shift problems" that shows the 3.2 conversion with the Boxster trans. IIRC, the guy said it would have been cheaper to buy a couple of complete Boxsters than do the swap, and that was back before early Boxes were less than $10K...
--DD |
PanelBilly |
Mar 18 2019, 04:09 PM
914 Guru Group: Members Posts: 5,796 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
You can just change the gears in your case to better match the /6. It might not be as strong, but you can make use of first rather than just starting in second. The only difficult part is having the gear for the stock 2nd cut off and a new one welded on.
dr914@autoatlanta.com |
Mar 18 2019, 04:12 PM
914 Guru Group: Members Posts: 7,811 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
would be neat for someone to install the complete Boxster power plant in a 914, but of course being water cooled makes it a big problem. Best just to install a big air cooled six. The 914 transmissions are always good enough, in my opinion
Mark Henry |
Mar 19 2019, 05:43 AM
would be neat for someone to install the complete Boxster power plant in a 914, but of course being water cooled makes it a big problem. Best just to install a big air cooled six. The 914 transmissions are always good enough, in my opinion Engine is too wide, they're freaking heavy, plus I charge $30K-ish to rebuild a M96 engine, may as well do a well sorted /6. Although this 4.0 400hp NA 996 C4S engine I'm just finishing up would be fun. (IMG:style_emoticons/default/happy11.gif) Attached image(s) |
Lo-Fi Version | Time is now: 19th April 2024 - 02:36 PM |
