Dual Dellorto DHLA 40 Carbs, Racing carbs |
flmont |
Mar 13 2019, 10:19 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
would these carbs be good for a type 4 2.0 build bigger crank and cam set up ,they are asking for 350.00 OBO,..Thanks
yeahmag |
Mar 14 2019, 11:05 AM
Advanced Member Group: Members Posts: 2,420 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
You can get 36mm venturi's from folks other than CB.
http://vwparts.aircooled.net/Dellorto-DRLA...-venturi-36.htm I did have to trim about 1mm off of them for my carbs. Apparently there are quality control issues... |
SirAndy |
Mar 14 2019, 11:43 AM
Resident German Group: Admin Posts: 41,581 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You can get 36mm venturi's from folks other than CB. 36 seems too big for a 2.0L engine. I went down to 32 venturis on my 2056 to get rid of a annoying off idle flat spot. (IMG:style_emoticons/default/popcorn[1].gif) |
yeahmag |
Mar 14 2019, 12:28 PM
You can get 36mm venturi's from folks other than CB. 36 seems too big for a 2.0L engine. I went down to 32 venturis on my 2056 to get rid of a annoying off idle flat spot. (IMG:style_emoticons/default/popcorn[1].gif) Mine is a unique case. I run the car above 7K RPM for autocross. I don't have any flat spots, but everything is tweaked to the 9's. |
GregAmy |
Mar 14 2019, 02:02 PM
Advanced Member Group: Members Posts: 2,262 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Mine is a unique case. Mine too. Race only, cams/compression "warm" build by Foley. The "Dellorto Bible" is a (poorly-edited) book, filled with excellent info about these carbs. I recall it recommends 34s, along with some baseline jetting/air correction info. Get a copy of it. https://www.cbperformance.com/product-p/0101.htm Street car is all D-Jet, all the time... |
Lo-Fi Version | Time is now: 29th March 2024 - 05:22 AM |
