securing the spare tire cover so it doesn't move, anyone done this? |
914 RZ-1 |
Mar 14 2019, 11:42 AM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've decided I'd like to secure the spare tire cover in the front trunk so it doesn't move around. It seems a bit loose and I want to keep it from moving while driving into turns and over bumps, etc.
I am planning on bolting it to the spare tire with a long bolt going thru one of the wheel nut holes, thru a hole in the cover and a wing nut. But, before I do, I thought I'd see if there were others who had done it and see what they did. I'd like the spare tire to be bolted separately; in other words, I want to be able to lift up the cover without undoing the bolt that holds the tire in place. I store stuff under it. I'm making a new cover out of 5/8" plywood (it was free and I want something thicker than stock so it doesn't bend) and I'm not planning on adding any carpet. I'm just going to paint it black. |
johnhora |
Mar 14 2019, 01:05 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
It's not going anywhere in a street car...unless you are upside down If in a track car....it and the spare are weight....remove them The carpet actually helps it stay in place and not shift around |
Lo-Fi Version | Time is now: 4th May 2024 - 03:05 AM |
