securing the spare tire cover so it doesn't move, anyone done this? |
914 RZ-1 |
Mar 14 2019, 11:42 AM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've decided I'd like to secure the spare tire cover in the front trunk so it doesn't move around. It seems a bit loose and I want to keep it from moving while driving into turns and over bumps, etc.
I am planning on bolting it to the spare tire with a long bolt going thru one of the wheel nut holes, thru a hole in the cover and a wing nut. But, before I do, I thought I'd see if there were others who had done it and see what they did. I'd like the spare tire to be bolted separately; in other words, I want to be able to lift up the cover without undoing the bolt that holds the tire in place. I store stuff under it. I'm making a new cover out of 5/8" plywood (it was free and I want something thicker than stock so it doesn't bend) and I'm not planning on adding any carpet. I'm just going to paint it black. |
KELTY360 |
Mar 29 2019, 05:27 PM
914 Neferati Group: Members Posts: 5,030 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Overkill for a solution that didn't have a problem. Just because you can doesn't mean you should.
Lo-Fi Version | Time is now: 25th April 2024 - 03:20 AM |
