securing the spare tire cover so it doesn't move, anyone done this? |
914 RZ-1 |
Mar 14 2019, 11:42 AM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've decided I'd like to secure the spare tire cover in the front trunk so it doesn't move around. It seems a bit loose and I want to keep it from moving while driving into turns and over bumps, etc.
I am planning on bolting it to the spare tire with a long bolt going thru one of the wheel nut holes, thru a hole in the cover and a wing nut. But, before I do, I thought I'd see if there were others who had done it and see what they did. I'd like the spare tire to be bolted separately; in other words, I want to be able to lift up the cover without undoing the bolt that holds the tire in place. I store stuff under it. I'm making a new cover out of 5/8" plywood (it was free and I want something thicker than stock so it doesn't bend) and I'm not planning on adding any carpet. I'm just going to paint it black. |
jim_hoyland |
Mar 29 2019, 06:35 PM
Get that VIN ? Group: Members Posts: 9,254 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Years ago, I made a cooler to fit in the front trunk: used an A/C cover from a 914, cut a hole in the spare tire cover board, and ran a drain line out the bottom. There was always a cold-one up front... (IMG:style_emoticons/default/beer3.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 17th April 2024 - 12:25 PM |
