securing the spare tire cover so it doesn't move, anyone done this? |
914 RZ-1 |
Mar 14 2019, 11:42 AM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've decided I'd like to secure the spare tire cover in the front trunk so it doesn't move around. It seems a bit loose and I want to keep it from moving while driving into turns and over bumps, etc.
I am planning on bolting it to the spare tire with a long bolt going thru one of the wheel nut holes, thru a hole in the cover and a wing nut. But, before I do, I thought I'd see if there were others who had done it and see what they did. I'd like the spare tire to be bolted separately; in other words, I want to be able to lift up the cover without undoing the bolt that holds the tire in place. I store stuff under it. I'm making a new cover out of 5/8" plywood (it was free and I want something thicker than stock so it doesn't bend) and I'm not planning on adding any carpet. I'm just going to paint it black. |
sixnotfour |
Mar 29 2019, 06:55 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
post a pic of your trunk floor...there shoiuld be a very adequate factory mount...unless your 914 had AC..
914 RZ-1 |
Mar 29 2019, 08:40 PM
post a pic of your trunk floor...there shoiuld be a very adequate factory mount...unless your 914 had AC.. The factory mount holds the spare tire. I made something to hold the cover to the spare. I wanted them separate so when I unbolted the bolt that holds the cover down, the spare would still be attached. |
Lo-Fi Version | Time is now: 25th April 2024 - 11:43 AM |
