securing the spare tire cover so it doesn't move, anyone done this? |
914 RZ-1 |
Mar 14 2019, 11:42 AM
Porsche Padawan Group: Members Posts: 682 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've decided I'd like to secure the spare tire cover in the front trunk so it doesn't move around. It seems a bit loose and I want to keep it from moving while driving into turns and over bumps, etc.
I am planning on bolting it to the spare tire with a long bolt going thru one of the wheel nut holes, thru a hole in the cover and a wing nut. But, before I do, I thought I'd see if there were others who had done it and see what they did. I'd like the spare tire to be bolted separately; in other words, I want to be able to lift up the cover without undoing the bolt that holds the tire in place. I store stuff under it. I'm making a new cover out of 5/8" plywood (it was free and I want something thicker than stock so it doesn't bend) and I'm not planning on adding any carpet. I'm just going to paint it black. |
914 RZ-1 |
Mar 29 2019, 05:21 PM
I have an industrial design background so I'm often finding ways to make improvements. Not sure why this wasn't done originally; maybe it was a cost consideration. Here is the finished product:
It rests on the spare. I have a bolt going thru one of the bolt holes on the tire thru an aluminum plate bolted to the back of the cover. The wing nut tightens it down. I carry a tool box so the red straps are for securing the tool box to the cover. It works, so I thought I'd share. |
jim_hoyland |
Mar 29 2019, 06:30 PM
Get that VIN ? Group: Members Posts: 9,256 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have an industrial design background so I'm often finding ways to make improvements. Not sure why this wasn't done originally; maybe it was a cost consideration. Here is the finished product: It rests on the spare. I have a bolt going thru one of the bolt holes on the tire thru an aluminum plate bolted to the back of the cover. The wing nut tightens it down. I carry a tool box so the red straps are for securing the tool box to the cover. It works, so I thought I'd share. Nice job , (IMG:style_emoticons/default/smile.gif) |
914 RZ-1 |
Mar 29 2019, 08:37 PM
@jim_hoyland
Thanks, I appreciate that! How long did your cooler keep stuff cold? (IMG:style_emoticons/default/beerchug.gif) |
jim_hoyland |
Mar 30 2019, 05:56 AM
@jim_hoyland Thanks, I appreciate that! How long did your cooler keep stuff cold? (IMG:style_emoticons/default/beerchug.gif) All day. I used it for trips up the Central Coast several times. Going to part with it since I make fewer trips in the 914. |
Lo-Fi Version | Time is now: 19th April 2024 - 04:54 PM |
