Weird Engine Noise |
porsche914gt |
Mar 14 2019, 01:02 PM
Member Group: Members Posts: 86 Joined: 20-January 04 From: Los Angeles, CA Member No.: 1,581 Region Association: None |
Strange rattle after some new seals, so by process of elimination theres no shroud, no fan, no alternator, shell tranny just for the starter. I've used my steth, checked valves, lifters, have oil pressure, pulled each plug wire. Any thoughts before I tear it down and rebuild? Thanks.
Attached File(s) Engine_Noise.htm ( 581.66k ) Number of downloads: 106 |
altitude411 |
Mar 14 2019, 01:05 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
unable to open file (IMG:style_emoticons/default/confused24.gif)
David Billo |
Mar 14 2019, 01:23 PM
Member Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada |
burton73 |
Mar 14 2019, 02:41 PM
burton73 Group: Members Posts: 3,487 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I do not even want to say it. You know in your hart what you need to do. 1st,Do not run it anymore or it will just cost you more. You can look at the oil and see just how much metal is in it.
Bob B |
rhodyguy |
Mar 14 2019, 03:02 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Engine out. Then comes the 'while you're in there'. There should be plenty of good used engines down south.
Lo-Fi Version | Time is now: 23rd April 2024 - 03:59 AM |
