Stock Push Rod Length |
R Dub |
Mar 14 2019, 01:14 PM
Member Group: Members Posts: 123 Joined: 29-August 17 From: Burbs of Chicago Member No.: 21,387 Region Association: None |
Can anyone verify what the stock push rod length is for these cars?
From my research the stock length is 271mm and the stock part# 021-109-301-A. I ordered 2 of these to replace the 2 bent ones that I have. I have no history of what push rods were in my motor so I just assumed they were stock but it doesn't appear that way as my 2 new ones are about 1/4" longer than what was in there. Just want to verify before I go buy 6 more stock rods. |
R Dub |
Mar 16 2019, 06:18 PM
You can't just switch out the lifters, you have to change the cam as well. Hydraulic cam has a different profile than the stock FI cam, and there also was mild performance hydraulic carb cams. Yeah I have a new Web cam grind #86 with new solid lifters and a new cam gear on the way. I'm hoping that the stock push rods will work with this cam and the heads. Will have to check once I get the cam in and the heads back from Adrian at Headflow Masters |
Lo-Fi Version | Time is now: 27th April 2024 - 06:49 AM |
