911 front hubs- split washers or no |
twistedstang |
Mar 14 2019, 01:48 PM
Member Group: Members Posts: 219 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
I'm finishing up my five lug swap and hit a wall. On the aluminum 911 hubs, is it proper to use a split washer on the aluminum hub when bolting on the rotor? If so, should I run the bolt through the hub first so the split washer is on the rotor side instead? I'm worried they will mar the aluminum.
yeahmag |
Mar 14 2019, 02:28 PM
Advanced Member Group: Members Posts: 2,420 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I use a flat washer and non-locking 8mm nut torqued to spec.
Lo-Fi Version | Time is now: 28th March 2024 - 03:54 AM |
