911 front hubs- split washers or no |
twistedstang |
Mar 14 2019, 01:48 PM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
I'm finishing up my five lug swap and hit a wall. On the aluminum 911 hubs, is it proper to use a split washer on the aluminum hub when bolting on the rotor? If so, should I run the bolt through the hub first so the split washer is on the rotor side instead? I'm worried they will mar the aluminum.
mb911 |
Mar 14 2019, 02:53 PM
914 Guru Group: Members Posts: 6,805 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I use spring washers no split washers.
Lo-Fi Version | Time is now: 23rd April 2024 - 05:03 PM |
