911 front hubs- split washers or no |
twistedstang |
Mar 14 2019, 01:48 PM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
I'm finishing up my five lug swap and hit a wall. On the aluminum 911 hubs, is it proper to use a split washer on the aluminum hub when bolting on the rotor? If so, should I run the bolt through the hub first so the split washer is on the rotor side instead? I'm worried they will mar the aluminum.
bdstone914 |
Mar 15 2019, 03:19 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Spring washers are correct. The bolt goes through from the rotor side with the nut and washer against the hub.
Bruce |
Lo-Fi Version | Time is now: 24th April 2024 - 12:56 AM |
