1973 Tan Seats |
1973 Tan Seats |
Minerva's 914 |
Mar 17 2019, 04:49 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
I finally attempted to install my new interior including a set of tan seats but the driver's seat won't slide more than a third of the way back. These were supposed to be a set but I'm wondering if I got 2 passengers' and no drivers' seat. Are there any differences other than the positioning of the fore/aft adjuster, are they reversible and if not, how can I tell if I have 2 passenger seats (other than the position of the fore/aft adjuster as these came without the rails and adjusters attached.
(IMG:style_emoticons/default/confused24.gif) |
bbrock |
Mar 18 2019, 08:06 AM
Have you tried just loosening the bolts on the rails attached to the seat and sliding it in? Mine have a little bit of adjustment in them and I had tightened one of mine where it wasn't perfectly parallel which caused it to bind. After loosening a little, I was able to slide it on and off a few times to self align and then retighten. Just a thought.
Minerva's 914 |
Mar 18 2019, 08:11 AM
Have you tried just loosening the bolts on the rails attached to the seat and sliding it in? Mine have a little bit of adjustment in them and I had tightened one of mine where it wasn't perfectly parallel which caused it to bind. After loosening a little, I was able to slide it on and off a few times to self align and then retighten. Just thought. Sounds like a good idea. I think I'll remove the base rails and mount the seat on them with all of the bolts loose and see if I can get them to move smoothly on the floor and then tighten everything, take it back apart before reassembling it in the car. Thanks |
Lo-Fi Version | Time is now: 20th May 2024 - 03:45 PM |
