Brake caliper rebuild on '76 |
Gatornapper |
Mar 17 2019, 07:10 PM
Senior Member Group: Members Posts: 1,215 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
914 geniuses...
Wow, been over a year I think since I last posted here. Been totally tied up on other projects but now the 914 is front and center. 1/2 done rebuilding the Webbers, and before I go any further I need to rebuild the rear brake calipers. Can't find any caliper rebuild kits on Pelican.....any other source? I guess Suncoast Porsche might have them...... TIA, GN |
walterolin |
Mar 17 2019, 10:11 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
And having rebuilt my own (successfully), I would suggest that you go ahead and let Eric do them. Considering the cost of parts and supplies, and your time, his charge is a good deal.
Gatornapper |
Mar 18 2019, 09:14 AM
And having rebuilt my own (successfully), I would suggest that you go ahead and let Eric do them. Considering the cost of parts and supplies, and your time, his charge is a good deal. Walter...... Hmmm, thanks for the tip....been rebuilding calipers for years and not a big deal....as I'm retired (and often tired) my time is cheap, and usually do one in less than an hour. Seems shipping costs would make it too expensive, but I have a call into Eric now - left msg. Thanks! GN |
mepstein |
Mar 18 2019, 09:43 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
And having rebuilt my own (successfully), I would suggest that you go ahead and let Eric do them. Considering the cost of parts and supplies, and your time, his charge is a good deal. Walter...... Hmmm, thanks for the tip....been rebuilding calipers for years and not a big deal....as I'm retired (and often tired) my time is cheap, and usually do one in less than an hour. Seems shipping costs would make it too expensive, but I have a call into Eric now - left msg. Thanks! GN As Eric explained, It's the plating in the piston bore that is important to restore. Eric ships USPS priority flat rate so shipping is very reasonable. |
bbrock |
Mar 18 2019, 10:17 AM
And having rebuilt my own (successfully), I would suggest that you go ahead and let Eric do them. Considering the cost of parts and supplies, and your time, his charge is a good deal. Walter...... Hmmm, thanks for the tip....been rebuilding calipers for years and not a big deal....as I'm retired (and often tired) my time is cheap, and usually do one in less than an hour. Seems shipping costs would make it too expensive, but I have a call into Eric now - left msg. Thanks! GN As Eric explained, It's the plating in the piston bore that is important to restore. Eric ships USPS priority flat rate so shipping is very reasonable. Yep, they'll fit in a medium flat rate box so not too bad. I've rather enjoyed doing mine myself though. Hoping to send the caliper halves off for plating this week, but most of the work is in the disassembly and cleaning. I wanted to plate them myself but the power supply I have wasn't up to the task. I find doing projects like this the adult equivalent of building model planes when I was a kid. Sure, it's work, but fun also. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:23 AM |
