New FI fuel pump, Pressure / Updated.....but |
jim_hoyland |
Mar 18 2019, 12:07 PM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My previous Bosch FI pump would always maintain pressure after the engine is shut off; there is a fuel pressure gauge in line.
I just installed a new Bosch pump; now the pressure falls back to zero after turning the ignition off Should the circuit maintainin pressure ? |
914Sixer |
Mar 18 2019, 12:21 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Did you install the check valve? Some pumps may not have them. I am guessing that is why you have no residual pressure.
Mar 18 2019, 02:26 PM
The rollers in the original pump serve as a check valve. As does the valve part of the fuel pressure regulator. (The reg actually is a spring-loaded valve.) You either have something plumbed strangely, or there is a fault in the pump that is letting fuel back out past the rollers.
--DD |
jim_hoyland |
Mar 18 2019, 03:00 PM
No check valve. Only replaced the pump with the same model #
So, you are saying I should still get a pressure reading after stopping ? |
dr914@autoatlanta.com |
Mar 18 2019, 04:09 PM
914 Guru Group: Members Posts: 7,832 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
What year is your car, and what pump Jim?
My previous Bosch FI pump would always maintain pressure after the engine is shut off; there is a fuel pressure gauge in line. I just installed a new Bosch pump; now the pressure falls back to zero after turning the ignition off Should the circuit maintainin pressure ? |
jim_hoyland |
Mar 18 2019, 05:09 PM
What year is your car, and what pump Jim? My previous Bosch FI pump would always maintain pressure after the engine is shut off; there is a fuel pressure gauge in line. I just installed a new Bosch pump; now the pressure falls back to zero after turning the ignition off Should the circuit maintainin pressure ? Its a Bosch 69469, same as my original. The car is a ‘75 L-Jet. Car starts right up, haven’t driven it yet. The new pump was made in Ceckislovakia (so) and not Germany like the original. |
Mar 19 2019, 10:24 AM
should hold some residual pressure, Jim, are you positive that you do not have a leak somewhere?
jim_hoyland |
Mar 19 2019, 11:32 AM
No leaks; the previous pump would slowly dissipate the pressure after shutdown.
I’ve inquired with the vendor. Will post their response. should hold some residual pressure, Jim, are you positive that you do not have a leak somewhere? What year is your car, and what pump Jim? My previous Bosch FI pump would always maintain pressure after the engine is shut off; there is a fuel pressure gauge in line. I just installed a new Bosch pump; now the pressure falls back to zero after turning the ignition off Should the circuit maintainin pressure ? Its a Bosch 69469, same as my original. The car is a ‘75 L-Jet. Car starts right up, haven’t driven it yet. The new pump was made in Ceckislovakia (so) and not Germany like the original. |
Mar 19 2019, 11:44 AM
Yes, you should absolutely have residual pressure after the pump stops.
Hard to hook up a two-port pump wrong, so there is a leak somewhere. Could be an injector sticking open, could be a leak out into the air (which would be pretty detectable by your nose), could be through the fuel pressure regulator back into the tank, could be back through the pump into the tank. --DD |
Mar 19 2019, 11:52 AM
so I would then change the pump.
No leaks; the previous pump would slowly dissipate the pressure after shutdown. I’ve inquired with the vendor. Will post their response. should hold some residual pressure, Jim, are you positive that you do not have a leak somewhere? What year is your car, and what pump Jim? My previous Bosch FI pump would always maintain pressure after the engine is shut off; there is a fuel pressure gauge in line. I just installed a new Bosch pump; now the pressure falls back to zero after turning the ignition off Should the circuit maintainin pressure ? Its a Bosch 69469, same as my original. The car is a ‘75 L-Jet. Car starts right up, haven’t driven it yet. The new pump was made in Ceckislovakia (so) and not Germany like the original. |
Mark Henry |
Mar 19 2019, 12:14 PM
In my bug I use a Ljet FP and have a big pressure gauge, it takes several hours to bleed down.
jim_hoyland |
Mar 19 2019, 03:29 PM
Just got off the phone with a very knowledgeable Bosch Automotive Tech person; he reviewed the specs for the pump before returning my call and stated the pumps have check valves and pressure should gradually dissipate after shut down.
Update: I removed the new Bosch pump and put the spare back in. Same thing happens with the old one too. Is is possible the pressure regulator has failed ? I never heard of one not working. There is no small of gas leaking out of the system, and the pressure goes right up to 30 when the engines running. Any ideas ? |
jim_hoyland |
Mar 19 2019, 05:04 PM
Yes, you should absolutely have residual pressure after the pump stops. Hard to hook up a two-port pump wrong, so there is a leak somewhere. Could be an injector sticking open, could be a leak out into the air (which would be pretty detectable by your nose), could be through the fuel pressure regulator back into the tank, could be back through the pump into the tank. --DD How do you bench test the regulator ? |
914Sixer |
Mar 19 2019, 05:45 PM
924,944 and lots of Audis, VW have a check valve you can install inline with the pump outlet. On Ebay for Bosch one for under $22.
adolimpio |
Mar 19 2019, 08:04 PM
Art Group: Members Posts: 180 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
I had a similar problem and isolated the culprit this way.
Attach a pressure gauge. Activate the pump to pressurize system. Have a pair of hemostats positioned at various point on fuel line. Deactivate the pump and immediately clamp the hose with the hemostats. Repeat the above for each of the following positions for the hemostats: Return line from regulator to eliminate regulator as the cause Output of pump to eliminate back flow through the pump Each injector to eliminate leaking injector My culprit turned out to be a leaking injector |
jim_hoyland |
Mar 19 2019, 08:31 PM
I had a similar problem and isolated the culprit this way. Attach a pressure gauge. Activate the pump to pressurize system. Have a pair of hemostats positioned at various point on fuel line. Deactivate the pump and immediately clamp the hose with the hemostats. Repeat the above for each of the following positions for the hemostats: Return line from regulator to eliminate regulator as the cause Output of pump to eliminate back flow through the pump Each injector to eliminate leaking injector My culprit turned out to be a leaking injector Thanks ! I will try that... (IMG:style_emoticons/default/smile.gif) I have an on-line pressure gauge already. Did the leaking injector cause the pressure to instantly fall to zero when the power was removed ? |
adolimpio |
Mar 21 2019, 06:13 AM
I had a similar problem and isolated the culprit this way. Attach a pressure gauge. Activate the pump to pressurize system. Have a pair of hemostats positioned at various point on fuel line. Deactivate the pump and immediately clamp the hose with the hemostats. Repeat the above for each of the following positions for the hemostats: Return line from regulator to eliminate regulator as the cause Output of pump to eliminate back flow through the pump Each injector to eliminate leaking injector My culprit turned out to be a leaking injector Thanks ! I will try that... (IMG:style_emoticons/default/smile.gif) I have an on-line pressure gauge already. Did the leaking injector cause the pressure to instantly fall to zero when the power was removed ? It took about 10 seconds to get to zero. |
Olympic 914 |
Mar 22 2019, 06:54 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
using a Bosch 044 pump, it came with a check valve that I left off when I installed it.
Was there a reason I should have left it on? Kind of late now since I would have to remove the tank to access it. |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:01 AM |
