Battery Size, Dimensions/Brand |
Chip |
Mar 18 2019, 05:15 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
I have a new battery tray. It measures approx. 9 1/2" x 7 1/4".
The class of battery I found is 42, but it seems too long. I also see a 24 series. What size battery do I need and please suggest a brand. Thanks mucho? Chip |
Chris914n6 |
Mar 18 2019, 07:49 PM
Jackstands are my life. Group: Members Posts: 3,305 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I use a 24 as it's the same one in my daily, but we can go as small as a Miata battery with no problem.
As far as off the shelf brand, Walmart gold top. Made by Johnson Controls which is the top battery maker in the US. Plus it's much cheaper than parts stores these days. Others will recommend a more specialized battery if it fits your budget, or just read one of the other threads. |
914Sixer |
Mar 18 2019, 07:52 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Group 42 battery.
Chip |
Mar 18 2019, 08:55 PM
I use a 24 as it's the same one in my daily, but we can go as small as a Miata battery with no problem. As far as off the shelf brand, Walmart gold top. Made by Johnson Controls which is the top battery maker in the US. Plus it's much cheaper than parts stores these days. Others will recommend a more specialized battery if it fits your budget, or just read one of the other threads. Thanks to you. |
Chip |
VaccaRabite |
Mar 19 2019, 07:11 AM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have also found some 42 sized batteries not to fit on the tray without trimming the battery footprint. (in my case it was an Optima RedTop.) Right now I'm using an Odyssey 925 sealed battery and its awesome. Zach |
Mark Henry |
Mar 19 2019, 07:40 AM
I have also found some 42 sized batteries not to fit on the tray without trimming the battery footprint. (in my case it was an Optima RedTop.) Right now I'm using an Odyssey 925 sealed battery and its awesome. Zach (IMG:style_emoticons/default/agree.gif) with the Odyssey 925, but it needs a custom mount, I made a strap out of SS. Best for the 914 is a sealed battery. |
914Sixer |
Mar 19 2019, 07:52 AM
I was asking around the other day about batteries. I do not know if this is gospel. I was told IF you do not use the correct group battery for the car you have, the battery will not be warrantied. The only way I see that happening is IF it is dealer installed.
dr914@autoatlanta.com |
Mar 19 2019, 08:33 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
42 should fit perfectly, same as vw beetle also the factory battery cover fits the 42 battery best
I have a new battery tray. It measures approx. 9 1/2" x 7 1/4". The class of battery I found is 42, but it seems too long. I also see a 24 series. What size battery do I need and please suggest a brand. Thanks mucho? Chip |
Chip |
Mar 19 2019, 10:31 AM
I have also found some 42 sized batteries not to fit on the tray without trimming the battery footprint. (in my case it was an Optima RedTop.) Right now I'm using an Odyssey 925 sealed battery and its awesome. Zach Terrific! Thanks. |
Chip |
Mar 19 2019, 03:18 PM
I was asking around the other day about batteries. I do not know if this is gospel. I was told IF you do not use the correct group battery for the car you have, the battery will not be warrantied. The only way I see that happening is IF it is dealer installed. You are correct. |
Lo-Fi Version | Time is now: 28th April 2024 - 03:17 PM |
