First Startup, Crank-By-Hand |
Chip |
Mar 19 2019, 10:38 AM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
I'm ready to crank the engine over for the first time in 30 yrs. (Lots of stories like this.) We've invited the neighborhood. I've changed the fuel lines, filter, cleaned pump, oil drain, tank, new sending unit, screen, topped off cylinders with MMO, cleaned plugs, etc. I'd like to turn the engine by hand, but don't know where to begin.
Any help, as I am alone and have no reference, alliance, resources or sanity. Thanks. (IMG:style_emoticons/default/agree.gif) |
BeatNavy |
Mar 19 2019, 10:51 AM
If you can get two hands on the impeller, you can use that to turn it by hand. Be careful not to put pressure on the blades themselves. If it doesn't budge that way, you can put the car in 5th gear, raise ONE rear wheel (keep the other on the ground and stationary), and use the one raised wheel to turn the engine. If THAT doesn't work, you may have to rock the car back and forth with it in gear for a while.
If you put MMO in there, be prepared for a nice white/grey smoke once it does fire up. The neighbors will love you. Ask me how I know. Good luck. |
Chip |
Mar 19 2019, 11:09 AM
If you can get two hands on the impeller, you can use that to turn it by hand. Be careful not to put pressure on the blades themselves. If it doesn't budge that way, you can put the car in 5th gear, raise ONE rear wheel (keep the other on the ground and stationary), and use the one raised wheel to turn the engine. If THAT doesn't work, you may have to rock the car back and forth with it in gear for a while. If you put MMO in there, be prepared for a nice white/grey smoke once it does fire up. The neighbors will love you. Ask me how I know. Good luck. Thanks, Rob! |
sixnotfour |
Mar 19 2019, 11:13 AM
914 Wizard Group: Members Posts: 10,406 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Good Luck ...1.25 hours away,,, Tooele
Rider914 |
Mar 19 2019, 11:20 AM
Member Group: Members Posts: 276 Joined: 13-April 04 From: Palm Beach Member No.: 1,923 |
I recently started a K5 blazer that was given to me and had sat for years. I put oil in the cylinders, let it soak, then cranked with the plugs still out but grounded so the spark would have a path other than through the distributor cap insulation. This sprays oil on the headers a bit but better than bending a rod if you used too much.
Chip |
Mar 19 2019, 03:11 PM
I recently started a K5 blazer that was given to me and had sat for years. I put oil in the cylinders, let it soak, then cranked with the plugs still out but grounded so the spark would have a path other than through the distributor cap insulation. This sprays oil on the headers a bit but better than bending a rod if you used too much. Great help! Thanks much. Chip |
Chip |
Mar 19 2019, 03:13 PM
ctc911ctc |
Mar 19 2019, 03:27 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Chip,
I started a garage find last year after 40 years of storage. STRONGLY recommend miracle oil in each cylinder and cranking the beast without Fuel or Plugs for 30-40 seconds and then stop. Wait 5 minutes and then again. Perhaps 10+ cycles of this. Get the oil pressure UP make it squeeze to the outer reaches This will not guarantee a healthy engine, but should protect the engine somewhat. Did I mention you should put some miracle oil in each cylinder........really,,,,,,do this....... GOOD LUCK WITH THE TEENER! I'm ready to crank the engine over for the first time in 30 yrs. (Lots of stories like this.) We've invited the neighborhood. I've changed the fuel lines, filter, cleaned pump, oil drain, tank, new sending unit, screen, topped off cylinders with MMO, cleaned plugs, etc. I'd like to turn the engine by hand, but don't know where to begin. Any help, as I am alone and have no reference, alliance, resources or sanity. Thanks. (IMG:style_emoticons/default/agree.gif) |
Superhawk996 |
Mar 19 2019, 05:59 PM
914 Guru Group: Members Posts: 5,726 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Be prepared to find the clutch plate to be stuck to the flywheel after that length of time. Start in neutral. Be prepared to not be able to disengage the clutch to put in gear or take out of gear with the engine running.
Be prepared for the worst. Recommend starting it on jack stands. If it isn’t stuck great. You’ll have gotten off easy |
Chip |
Mar 20 2019, 12:14 AM
Chip, I started a garage find last year after 40 years of storage. STRONGLY recommend miracle oil in each cylinder and cranking the beast without Fuel or Plugs for 30-40 seconds and then stop. Wait 5 minutes and then again. Perhaps 10+ cycles of this. Get the oil pressure UP make it squeeze to the outer reaches This will not guarantee a healthy engine, but should protect the engine somewhat. Did I mention you should put some miracle oil in each cylinder........really,,,,,,do this....... GOOD LUCK WITH THE TEENER! Thanks so much. Tried to crank it today, but I don't think there is petrol getting to the engine. Fuel pump did not buzz upon turning key. The starter seemed ok, but no turnover. Need to check power to FP terminals, then see if pump is bad. I cleaned it out and hooked it up to a battery and it seemed ok. Can you provide a checklist for fuel, spark, etc? Thanks and thank you. ! I'm ready to crank the engine over for the first time in 30 yrs. (Lots of stories like this.) We've invited the neighborhood. I've changed the fuel lines, filter, cleaned pump, oil drain, tank, new sending unit, screen, topped off cylinders with MMO, cleaned plugs, etc. I'd like to turn the engine by hand, but don't know where to begin. Any help, as I am alone and have no reference, alliance, resources or sanity. Thanks. (IMG:style_emoticons/default/agree.gif) |
Chip |
Mar 20 2019, 12:17 AM
Be prepared to find the clutch plate to be stuck to the flywheel after that length of time. Start in neutral. Be prepared to not be able to disengage the clutch to put in gear or take out of gear with the engine running. Be prepared for the worst. Recommend starting it on jack stands. If it isn’t stuck great. You’ll have gotten off easy Thanks. Car is on stands. No turnover yet. May be bad fuel pump. Need to check power to FP terminals. Fun to see the headlamps flip up and down, horn, turn signals, back-up lights, etc. Hope clutch is free. |
Lo-Fi Version | Time is now: 20th April 2024 - 03:42 AM |
