Would the welders look at this please |
BPic |
Mar 19 2019, 06:59 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I've been welding in this car for a year and never had anything like this happen.
I ran out of gas and the welder was doing fine. Got a new bottle delivered today and hooked it up. When I started welding it sounded different, lots of soot, the metal doesn't puddle the way it did before and the welds look like crap! (IMG:style_emoticons/default/headbang.gif) The other thing that happens is that the wire fuses itself to the gun tip. Settings are the same on the machine and everything was fine. The only thing that changed was a new bottle of gas. I'm sure it's possible for them to put the wrong mix or the wrong gas but before I call them is there something else I should be looking at? (IMG:style_emoticons/default/confused24.gif) Thanks in advance, Brad |
tazz9924 |
Mar 19 2019, 08:11 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
It looks like you are missing a good amount of gas. Possibilities: Did you take off the wire feed hose? somtimes when you put the feed hose back on it doesn’t go all the way in and it leaks gas, listen for leaks near the machine and gas coming out of the gun/ torch when you hit the button. What type of gas do you have? co2 air mix for mig, argon for tig. Is the gas on (stupid sounding question but you never know)? Is the flow rate high enough? depending on machine and wind. On mig it’s about 20-35 gph (or was it liters per hour..... just read what it says on ur machine). Just give everything a good once over and im sure you’ll find the problem, good luck!
Lo-Fi Version | Time is now: 21st May 2024 - 10:25 AM |
