Would the welders look at this please |
BPic |
Mar 19 2019, 06:59 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I've been welding in this car for a year and never had anything like this happen.
I ran out of gas and the welder was doing fine. Got a new bottle delivered today and hooked it up. When I started welding it sounded different, lots of soot, the metal doesn't puddle the way it did before and the welds look like crap! (IMG:style_emoticons/default/headbang.gif) The other thing that happens is that the wire fuses itself to the gun tip. Settings are the same on the machine and everything was fine. The only thing that changed was a new bottle of gas. I'm sure it's possible for them to put the wrong mix or the wrong gas but before I call them is there something else I should be looking at? (IMG:style_emoticons/default/confused24.gif) Thanks in advance, Brad |
bretth |
Mar 22 2019, 01:01 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I wonder if this can be caused by the last person that rented the welding tank leaving it open to the air for a period of time. I remember reading that you should leave at least 50lbs of pressure in the tank and not let it get completely empty to reduce chance of moisture inside.
Jeff Hail |
Mar 22 2019, 06:58 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I wonder if this can be caused by the last person that rented the welding tank leaving it open to the air for a period of time. I remember reading that you should leave at least 50lbs of pressure in the tank and not let it get completely empty to reduce chance of moisture inside. Rusty tanks are common. Iron tends to plug orifices in the regulator. |
Lo-Fi Version | Time is now: 30th April 2024 - 09:18 PM |
