Would the welders look at this please |
roblav1 |
Mar 22 2019, 10:40 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I've been using ER70-S6, with fair results on the rusted spots.
BPic |
Mar 22 2019, 11:37 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
New gas bottle and it's laying some nice welds. (IMG:style_emoticons/default/welder.gif)
Gues is was just bad gas. Wife said I've had that before. (IMG:style_emoticons/default/bootyshake.gif) |
Superhawk996 |
Mar 22 2019, 12:41 PM
914 Guru Group: Members Posts: 5,725 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
New gas bottle and it's laying some nice welds. (IMG:style_emoticons/default/welder.gif) Gues is was just bad gas. Wife said I've had that before. (IMG:style_emoticons/default/bootyshake.gif) Awesome news. It's baffling for sure and I've only had it ever happen once. Quality control is easy to say but hard to do day in and day out. I've wondered how it happens but honestly after you change the tank you just get back to the project. (IMG:style_emoticons/default/welder.gif) Weld On! |
bretth |
Mar 22 2019, 01:01 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I wonder if this can be caused by the last person that rented the welding tank leaving it open to the air for a period of time. I remember reading that you should leave at least 50lbs of pressure in the tank and not let it get completely empty to reduce chance of moisture inside.
Jeff Hail |
Mar 22 2019, 06:57 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
New gas bottle and it's laying some nice welds. (IMG:style_emoticons/default/welder.gif) Gues is was just bad gas. Wife said I've had that before. (IMG:style_emoticons/default/bootyshake.gif) Awesome! When you wrote your were experiencing wire sticking to the tip it usually indicates other issues. Glad you got it handled. |
Jeff Hail |
Mar 22 2019, 06:58 PM
I wonder if this can be caused by the last person that rented the welding tank leaving it open to the air for a period of time. I remember reading that you should leave at least 50lbs of pressure in the tank and not let it get completely empty to reduce chance of moisture inside. Rusty tanks are common. Iron tends to plug orifices in the regulator. |
Jeff Hail |
Mar 22 2019, 07:00 PM
Still curious if OP's problem went away. @Jeff Hail Jeff, any advice on TIG'ing Galvanneal? I've tried grinding it back (both sides) but some of the zinc is actually annealed into the steel and can't be removed by grinding and still leads to electrode contamination and puddle pops. Not an issue for MIG. At this point it's painfully slow with TIG but I'm surviving. However, the thought of going back to a MIG rig has crossed my mind several times now. Best success I've had is by feeding as much filler as quickly as I can. I suspect it helps dilute the zinc in the puddle by getting fresh filler (ER70-S2) in there. Apologize for thread high jack. I'll post fresh thread if I've offended anyone but this appears to have the attention of the welders among us. I'm really not a Tig man. Foley would be my go to guy for Tig. |
Mar 22 2019, 07:32 PM
914-6 GT in waiting Group: Members Posts: 19,222 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Still curious if OP's problem went away. @Jeff Hail Jeff, any advice on TIG'ing Galvanneal? I've tried grinding it back (both sides) but some of the zinc is actually annealed into the steel and can't be removed by grinding and still leads to electrode contamination and puddle pops. Not an issue for MIG. At this point it's painfully slow with TIG but I'm surviving. However, the thought of going back to a MIG rig has crossed my mind several times now. Best success I've had is by feeding as much filler as quickly as I can. I suspect it helps dilute the zinc in the puddle by getting fresh filler (ER70-S2) in there. Apologize for thread high jack. I'll post fresh thread if I've offended anyone but this appears to have the attention of the welders among us. I'm really not a Tig man. Foley would be my go to guy for Tig. I think Ben teaches tig. |
sithot |
Mar 22 2019, 08:17 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
QUOTE I think Ben teaches tig. Understatement. Yes, he teaches it alright. (IMG:style_emoticons/default/pray.gif) |
mb911 |
Mar 22 2019, 08:50 PM
914 Guru Group: Members Posts: 6,801 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Yup teach TIG including stainless, aluminum, magnesium, titanium, 4130, and steels.
Also teach Smaw, MIG, flux core , print reading and fabrication and a division chair for the construction trades at our college for 18 years and worked in avaition prior to that. I am pretty versed in this (IMG:style_emoticons/default/biggrin.gif) Oh and owned multiple welding and fab business over the last 15 year's 1 being M&k exhaust and 1 being 914-6werkshop.com Sorry just putting it out there for those that may not know. (IMG:style_emoticons/default/poke.gif) |
mb911 |
Mar 22 2019, 08:55 PM
Oh and you welding galvaneel is a challenge it will pop back no matter what you do.. It is through galvanized so it can't be ground away .
Mar 22 2019, 08:59 PM
I thought you might do ti. We will have to talk about that. (IMG:style_emoticons/default/biggrin.gif)
Joemo5 |
Mar 23 2019, 09:20 AM
Member Group: Members Posts: 54 Joined: 1-April 18 From: Charlotte, North Carolina Member No.: 22,011 Region Association: South East States |
I'm definitely no expert but I've heard that welding through galvanized or zinc coatings can give off dangerous fumes so be cautious.
Speaking of shielding gas though, I've caught myself holding the mig gun too far away or at a bad angle in order to get better view of the puddle which resulted in similar results to the OP's issue. Moving the gun more upright and keeping the tip around 3/8 from the work piece improved my results. Glad to see the new bottle fixed the issue though. |
Superhawk996 |
Mar 23 2019, 10:03 AM
Oh and you welding galvaneel is a challenge it will pop back no matter what you do.. It is through galvanized so it can't be ground away . That's what I was afraid of based on nature of Galvanneal. (IMG:style_emoticons/default/sad.gif) I've also had some success improving the situation by using a 2Hz pulse which seems to minimize the pops. I'll reach out to RD and Chris but as far as I can tell RD MIG's based on their videos. I migrated to TIG for flexibility and my garage is too small and cluttered to have MIG sparks flying around. I'll keep making do but a MIG rig looks more and more appealing. Thank for the advice guys (IMG:style_emoticons/default/beerchug.gif) |
mb911 |
Mar 23 2019, 01:59 PM
Oh and you welding galvaneel is a challenge it will pop back no matter what you do.. It is through galvanized so it can't be ground away . That's what I was afraid of based on nature of Galvanneal. (IMG:style_emoticons/default/sad.gif) I've also had some success improving the situation by using a 2Hz pulse which seems to minimize the pops. I'll reach out to RD and Chris but as far as I can tell RD MIG's based on their videos. I migrated to TIG for flexibility and my garage is too small and cluttered to have MIG sparks flying around. I'll keep making do but a MIG rig looks more and more appealing. Thank for the advice guys (IMG:style_emoticons/default/beerchug.gif) Sure because the. The heat is working in low amp/hi amp cycling.. That would help a bit. Ps all should be wearing respirators like the Miller lpr-100 or equivalent to protect from fumes.. |
Lo-Fi Version | Time is now: 19th April 2024 - 03:42 PM |
