**SOLD** Early 3" 911 Struts housings w/ inserts & 2x 47mm offset 5-lug Hubs |
RichPugh |
Mar 19 2019, 08:20 PM
Member Group: Members Posts: 121 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
73-76 911 5 lug stuff... 1x 911.341.079.02 & 1x 911.341.080.02 w/ inserts (mileage unknown) and 2x aluminum hubs 901.341.605.3 R plus 10x studs and 2x center caps. I decided to go w/ 3.5" struts and so these will hopefully go to make some 914 owner a lovely 5 lug front end without having to swap brakes.
SOLD (IMG:http://www.914world.com/bbs2/uploads_offsite/farm8.staticflickr.com-18068-1553048426.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm8.staticflickr.com-18068-1553048427.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm8.staticflickr.com-18068-1553048427.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm8.staticflickr.com-18068-1553048428.4.jpg) |
Mar 19 2019, 08:32 PM
I'm pretty sure they are Bilstein inserts.
RichPugh |
Mar 19 2019, 08:50 PM
roblav1 |
Mar 19 2019, 10:24 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Slight clarification... 65-68 MY are different. Best of luck with sale and your progress.
bdstone914 |
Mar 20 2019, 06:48 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Do you have the spindle nuts and keyed washers? If not I have sets of them.
bdstone914 |
Mar 20 2019, 08:06 AM
Slight clarification... 65-68 MY are different. Best of luck with sale and your progress. These are 73-76 911 struts. They are better taper pin type. One of the best struts to use. Earlier 1969-72 struts were pinch bolt type. These can be used on any year 914 if the matching taper pin ball joints are used. Good luck with sale. Bruce |
bdstone914 |
Mar 20 2019, 08:14 AM
Rich,
Your comment below is not accurate. "these will hopefully go to make some 914 owner a lovely 5 lug front end without having to switch brakes." These use vented 911 rotors. 914 calipers are for solid rotors. They need either M 911 calipers, or Alfa calipers. @RichPugh |
Mar 20 2019, 08:18 AM
Rich, Your comment below is not accurate. These use vented 911 rotors. 914 calipers are for solid rotors. They need either M 911 calipers, or Alfa calipers. ." these will hopefully go to make some 914 owner a lovely 5 lug front end without having to switch brakes." Yea, you need “911” brakes for these. But M calipers are what came on the 914-6 and are very available from the 911 guys who move up to 3.5” struts. |
RichPugh |
Mar 20 2019, 03:13 PM
QUOTE Rich, Your comment below is not accurate. "these will hopefully go to make some 914 owner a lovely 5 lug front end without having to switch brakes." These use vented 911 rotors. 914 calipers are for solid rotors. They need either M 911 calipers, or Alfa calipers. QUOTE Yea, you need “911” brakes for these. But M calipers are what came on the 914-6 and are very available from the 911 guys who move up to 3.5” struts. Crap, you guys are right! I'm sorry... I forgot the previous owner did a BMW 320 caliper swap... Welp, I edited the original Post. My apologies, all! Still great struts to go 5-lug with! |
RichPugh |
Mar 20 2019, 03:33 PM
Lo-Fi Version | Time is now: 26th April 2024 - 06:13 PM |
