Reviving NOS Webers, Initial Settings? |
bbrock |
Mar 20 2019, 08:55 PM
I didn't want to hijack the other thread but have a question about my own Webers. They are Italian 40IDFs I bought in the late 80s or early 90s. Other than finger tight bolting them on to my engine to see how cool they looked, they have never been used. No fuel has touched them. I don't remember if I even opened them to set the float levels. BUT... they were stored in a humid basement for several years before I moved to a civilized climate. So, the magnesium housing is tarnished on the outside and the plating has deteriorated on a few of the levers and such. Pretty minor stuff from what I can see.
My question: is there is anything special I should do or check other than inspecting for corroded parts and normal setup as I prep these for service? |
tmessenger |
Mar 21 2019, 07:53 AM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
The float needle tip can harden with age so I replace those along with pump diaphragms. Check your fuel pressure you'll want 3 ~ 3.5 psi.
Your 40 IDF's may have come with 28mm venturi, this is fine for a stock 1.7 or 1.8 if you have a 2L I would recommend 32mm venturi. Note: The vintage IDF's are not drilled for port vacuum, they have manifold vacuum only (the vacuum port is below the throttle plate). Depending on which distributor you are running you may or may not be fine with a lot of vacuum advance at idle? I wanted my vacuum advance to drop out at idle so I set up an electric vacuum switch and control it with a micro switch on the carb linkage. Tim |
Lo-Fi Version | Time is now: 28th March 2024 - 12:56 PM |
