Reviving NOS Webers, Initial Settings? |
bbrock |
Mar 20 2019, 08:55 PM
I didn't want to hijack the other thread but have a question about my own Webers. They are Italian 40IDFs I bought in the late 80s or early 90s. Other than finger tight bolting them on to my engine to see how cool they looked, they have never been used. No fuel has touched them. I don't remember if I even opened them to set the float levels. BUT... they were stored in a humid basement for several years before I moved to a civilized climate. So, the magnesium housing is tarnished on the outside and the plating has deteriorated on a few of the levers and such. Pretty minor stuff from what I can see.
My question: is there is anything special I should do or check other than inspecting for corroded parts and normal setup as I prep these for service? |
IronHillRestorations |
Sep 6 2020, 11:50 AM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I went back and re-read some of this thread. I'd recommend disabling the cold start plungers. I've never seen those used on a 914, but I have seen where the mechanism got janked with, stuck and made it run fat as a hog, to the point of diluting the oil with gas.
You've taken the mechanism off, and properly blocked it off. I'd take the next step which is to tap the plunger bore for a 3/8 x 16 and install a brass hex socket head set screw to keep the plungers in place. I just did this on an engine about a month ago. I got some brass plugs off ebay. brass set screws I chucked up a 3/8 x 16 tap in my drill press and turned it by hand to start the tap, and make sure it was lined up. @bbrock Cold start disable on Weber carb |
Lo-Fi Version | Time is now: 24th April 2024 - 10:25 PM |
