CV joint part numbers?, update April 2019 |
larryM |
Mar 21 2019, 03:56 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
going thru my stash, prepping for the yard sale
have 2 Lobro CV's in old boxes - believe one is -6, per fella i got it from long ago 914 3320 2903 - is 914-4 all ? 914 3320 2901 - is what? - any help? update - lot's of good info in responses below - so I finally unboxed 'em & counted the splines 04-02-2019 the 029 01 is a -6- CV, appears to be new - in a oldish cardboard-brown box with blue Lobro printing the 029 03 is a -4- CV, also appears to be new - in a yellow Lobro box that has seen a bit of haphazard shelf life - both wrapped in brown oil-paper in the boxes fwiw - web searching the numbers comes up with varying & sometimes incorrect fitments on various of our parts-seller sites - i find the same part-number vs fit problem with new -6- rear cyl rebuild kits (ATE) that i have had for awhile - b'ot 'em back when they were NLA, from E.A.S.Y.'s last stock - "if they say it on the internet .... it may not be true" |
bbrock |
Mar 21 2019, 04:40 PM
914 332 029 03 is the correct 914-4 part number.
Mark Henry |
Mar 21 2019, 05:10 PM
914 332 029 03 is the correct 914-4 part number. This ad (first link I clicked on google) says 914 332 029 01 has been superseded by 914 332 029 03 so likely they are both /4 CV's. https://www.sonnenporscheoemparts.com/oem-p...int-91433202903 |
bbrock |
Mar 21 2019, 05:19 PM
914 332 029 03 is the correct 914-4 part number. This ad (first link I clicked on google) says 914 332 029 01 has been superseded by 914 332 029 03 so likely they are both /4 CV's. https://www.sonnenporscheoemparts.com/oem-p...int-91433202903 This could explain a problem @76-914 and I are having. We both ordered 914 332 029 03 joints from Sunset Porsche and what we received were 25-spine joints which are for sixes. Still waiting on PCNA to weigh in on the problem. They can change the part numbers all they want, but it won't make them fit the axles. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:52 PM |
