CV joint part numbers?, update April 2019 |
larryM |
Mar 21 2019, 03:56 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
going thru my stash, prepping for the yard sale
have 2 Lobro CV's in old boxes - believe one is -6, per fella i got it from long ago 914 3320 2903 - is 914-4 all ? 914 3320 2901 - is what? - any help? update - lot's of good info in responses below - so I finally unboxed 'em & counted the splines 04-02-2019 the 029 01 is a -6- CV, appears to be new - in a oldish cardboard-brown box with blue Lobro printing the 029 03 is a -4- CV, also appears to be new - in a yellow Lobro box that has seen a bit of haphazard shelf life - both wrapped in brown oil-paper in the boxes fwiw - web searching the numbers comes up with varying & sometimes incorrect fitments on various of our parts-seller sites - i find the same part-number vs fit problem with new -6- rear cyl rebuild kits (ATE) that i have had for awhile - b'ot 'em back when they were NLA, from E.A.S.Y.'s last stock - "if they say it on the internet .... it may not be true" |
bbrock |
Mar 21 2019, 04:40 PM
914 332 029 03 is the correct 914-4 part number.
Mark Henry |
Mar 21 2019, 05:10 PM
914 332 029 03 is the correct 914-4 part number. This ad (first link I clicked on google) says 914 332 029 01 has been superseded by 914 332 029 03 so likely they are both /4 CV's. https://www.sonnenporscheoemparts.com/oem-p...int-91433202903 |
bbrock |
Mar 21 2019, 05:19 PM
914 332 029 03 is the correct 914-4 part number. This ad (first link I clicked on google) says 914 332 029 01 has been superseded by 914 332 029 03 so likely they are both /4 CV's. https://www.sonnenporscheoemparts.com/oem-p...int-91433202903 This could explain a problem @76-914 and I are having. We both ordered 914 332 029 03 joints from Sunset Porsche and what we received were 25-spine joints which are for sixes. Still waiting on PCNA to weigh in on the problem. They can change the part numbers all they want, but it won't make them fit the axles. (IMG:style_emoticons/default/headbang.gif) |
Mark Henry |
Mar 22 2019, 05:07 AM
914 332 029 03 is the correct 914-4 part number. This ad (first link I clicked on google) says 914 332 029 01 has been superseded by 914 332 029 03 so likely they are both /4 CV's. https://www.sonnenporscheoemparts.com/oem-p...int-91433202903 This could explain a problem @76-914 and I are having. We both ordered 914 332 029 03 joints from Sunset Porsche and what we received were 25-spine joints which are for sixes. Still waiting on PCNA to weigh in on the problem. They can change the part numbers all they want, but it won't make them fit the axles. (IMG:style_emoticons/default/headbang.gif) Yes, I didn't vet the source, just saw that ad on the first google search link that came up. Doesn't the new complete half shafts have a different spline count (or something different) than a regular /4 CV? .... the answer is ..... count the splines? Well.... 25 splines will be a /6, I'm sure someone will chime in with the number of splines on a /4 axle. |
bbrock |
Mar 22 2019, 07:43 AM
Doesn't the new complete half shafts have a different spline count (or something different) than a regular /4 CV? This was going to be my next question. I think it solves the mystery but doesn't make Kent or I happy. Bottom line is the complete axle assemblies appear to be from the /6 with 25 splines which would bolt right on to a /4 or /6. That means the 33-spline joints are truly NLA. The confusion started way back with the PET. It lists two entries for the complete shaft assembly, both with P/N 914-332-009-03. One entry shows it for a /6 and the other doesn't specify. The for the CV joint, they have only one P/N listed (914-332-029-03) which they say is for all /4 models. As Kent said, there is no part listed for the /6. I will bet that the correct P/N for the six is 914-332-009-01 for the axle and 914-332-029-01 for the joint. If you plug those P/Ns into the Porsche catalog, you get notes that both have been replaced by the 03 versions. That's actually backwards and while the axles are interchangeable, the stand alone joints are not. Unfortunately, Porsche has jacked the price of complete axles to $680 per side which is a ridiculously expensive way to replace a couple of joints. Bottom line, looks like I'm in the market for a couple of 33-spline joints again. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 12:02 AM |
