Pedal cluster rebuild, God I just love roll pins. NOT!! |
sholman5 |
Mar 23 2019, 05:18 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
Went to replace my carpet and to my what did I see? A greasy, rusty pedal cluster. Decided to tackle this one myself with a little help from a friend. Disassembly was not bad at all. Even the roll pin came out easily with the help of an air chisel. Sand blasted all of the parts, etch primed and painted. I let everything dry for a week. Today started assembling everything. Used bronze bushings, but the greatist fun all day was replacing the roll pin. It took a few hours, but we wanted to take our time and get it right the first. Ended up using a press to insert it along with a drill bit (smooth end) inserted on the opposite side to keep everything aligned. In the end it was very gratifying to rebuild. Not as nice as a bstone piece , but it is clean and functional. Greatful for all of the threads in the Garage forum.
Dave_Darling |
Mar 25 2019, 09:05 AM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The Weltmeister kits used to ship with pins that were not even a full spiral. They were notorious for failing. To the point where the first question we used to ask when someone had a loose clutch pedal was, "Did you just change the pedal bushings?"
I see spiral pins in Bruce's post and in Lierofox's post. Those are not notorious for failing. I don't know if WM finally figured out they needed a better pin, or if WM kits are even the ones being used above. --DD |
jcd914 |
Mar 25 2019, 10:13 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The Weltmeister kits used to ship with pins that were not even a full spiral. They were notorious for failing. To the point where the first question we used to ask when someone had a loose clutch pedal was, "Did you just change the pedal bushings?" I see spiral pins in Bruce's post and in Lierofox's post. Those are not notorious for failing. I don't know if WM finally figured out they needed a better pin, or if WM kits are even the ones being used above. --DD This was our experience too. We kept OE roll pins in stock and taped a new OE pin to each Weltmeister bushing kit we stocked. Jim |
Lo-Fi Version | Time is now: 18th May 2024 - 02:31 AM |
